Need suggestions/advice
Old Oct 3, 2007 | 08:46 PM
leemikemphstn's Avatar
Default Need suggestions/advice
I have a '98 Prelude and want to increase power without modifying the engine (turbo, supercharger, etc.). So far, all I've done is add an APEX exhaust which - according to a few guys - may or may not have increased horsepower. What about a cold-air intake system? Which one(s) should I look for and which one(s) should I not bother with. Also, I'm considering a module (Hondata), but does anyone have any info about the best deals available? Thanks for any help.
Old Oct 3, 2007 | 09:01 PM
dagle's Avatar
Default Re: Need suggestions/advice (leemikemphstn)
intake, headers, exhaust are the basic bolt-ons
you have tuning (hondata as u mentioned), cam gears, bigger tb or ITB's..
and theres things you can remove which frees up more power/ reduces weight.
these are some items that can be removed- (suit yourself)
power steering
air conditioning
Fast Idle Thermo Valve (only if your area doesn't get too cold)
Old Oct 3, 2007 | 09:05 PM
AaronW's Avatar
Default Re: Need suggestions/advice (dagle)
Go with a CAI first, as it's the easiest upgrade to do, and is relatively cheap.
Getting a good filter is more important than getting an expensive pipe. If you read up on CAIs, there's alot of argument over whether intakes like the AEM V2 are actually worth the money.
I'd recommend getting a CAI off of ebay, and buying a K&N filter to put on it, instead of the cheap-o one that will come with it.
Old Oct 3, 2007 | 09:13 PM
Acidcrakker's Avatar
Default Re: Need suggestions/advice (AaronW)
You can do basic upgrades. I/H/E For starters. You can actually add a hondata system on that set up, and if its tuned right, there will be gains.
Old Oct 3, 2007 | 09:55 PM
BrokenEM1's Avatar
convert to odb1 with a a converstion harness for like 80 bucks
get a chipped ecu for like 150-180 and someone who can tune it and you'll c gains fo shoooo
but im not talkin about turbo gains, lol but enough where the money pays off
Old Oct 4, 2007 | 02:58 AM
BlackCatt's Avatar
Definately get a CAI, AEM make great ones. You will notice a mild increase in torque and power and the prices are relatively cheap.
04TYPEsaggin
Feb 20, 2008 08:55 AM
Easyslider01
Sep 29, 2006 04:19 AM
4everVtec
24
Oct 30, 2005 04:46 AM
Don Jefe
Jun 10, 2005 07:17 AM
Toda RSXS
Nov 14, 2002 04:16 PM
