dohc zc swap fuel injector problems or other???????????
Old Oct 3, 2007 | 08:35 PM
viciousvisionslarry's Avatar
Default dohc zc swap fuel injector problems or other???????????
ok guy ive got a injector question for you. i did a dohc zc swap on my 89 hatchback dx. compression numbers good all the way across car ran like poop idled rough would stall i took it to jdm exchange here in philly. i had a code for my tps sensor they replaced it, but the car still ran bad i checked it for more codes it came back with exhast cam sensor and injector #1 code the car wouldnt start so i towed it to a friends house we replaced the cam sensor and when he pulled the spark plugs. when he pulled the number 1 plug fuel filled up the entire cylinder and plug tube. he unpluged the fuel pump and cranked the engine. when we pluged the pump back in with the key on the cylinder filled back up.is it a leaky injector or fpr?
Old Oct 4, 2007 | 06:27 PM
hondasaurusrex's Avatar
Default Re: dohc zc swap fuel injector problems or other??????????? (viciousvisionslarry)
did you do the dpfi to mpfi swap?
Old Oct 7, 2007 | 06:43 AM
949's Avatar
949
interesting.
Old Oct 7, 2007 | 07:37 AM
Default Re: dohc zc swap fuel injector problems or other??????????? (hondasaurusrex)
yes i did the wiring i fixedthe fuel thing now i belive i have a riming issue is stumbles at idle and its kind of clears up further up the rpms
Old Oct 7, 2007 | 09:13 AM
are you getting any codes?
Old Oct 7, 2007 | 09:20 AM
wiZCo's Avatar
Stouts 'n' Scotch
I'd be willing to bet it's a problem with the CPS or distributor wiring, those seem to be the most common problems with this swap.
As mentioned above, it could very well be a timing issue. Have you checked your ignition and engine timing?
Old Oct 7, 2007 | 05:35 PM
Default Re: (wiZCo)
you may very well have a stuck injector..
Old Oct 8, 2007 | 10:59 AM
Default Re: (wiZCo)
codes are 9 and 16 im thinking the dizzy wires are wrong
stella88
29
Jan 22, 2011 02:00 PM
oppositiontim
Dec 6, 2010 12:31 PM
89civichb
Jul 30, 2008 06:55 PM
96-EJ6 B18C
Apr 15, 2004 05:33 PM
DesiDez
Jul 16, 2003 08:26 AM
