question about cel codes (obd0 and obdI) thanks guys
Old Oct 3, 2007 | 06:30 PM
EL MIGGZ's Avatar
Default question about cel codes (obd0 and obdI) thanks guys
are the cel codes different from obd0 and obdI
thanks guys
Old Oct 3, 2007 | 06:49 PM
EL MIGGZ's Avatar
Default Re: question about cel codes (obd0 and obdI) thanks guys (EL MIGGZ)
i have had these codes on my pc but was wondering if they are the same for obd 0 and obdI
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
Laz's EP
22
Feb 22, 2010 12:09 AM
LoidBanks
Feb 25, 2009 11:16 PM
DA_Boy_626
Oct 3, 2007 06:50 PM
ooregulateoo
Mar 9, 2007 06:57 PM
BLuDoHcReX
Apr 3, 2003 07:36 PM
