Pics or Illustrations of how to change main relay?
I have seen a picture of where it is located but would like to know if there is a detailed write up or pictures that tells me exactly how.
I don't want to take a crap load of panels off and screws and find out it was just 2 that I need to take off.
Please help.
Thanks in advance
Yes I did search and did not come up with DETAILED instructions.
Please help.
Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cticknor666 »</TD></TR><TR><TD CLASS="quote">Its super easy. Its right up above your hood release. Its a little black box. All you do is remove the electrical conection. </TD></TR></TABLE>
LOL. if main relay, im thinking the one under the dash? above ur feet? that one i assume....just crawl under there, take a number 10/12 socket (forgot) and just unbolt one bolt holding it up and pull it out , unplug, plug in new one, bolt it back up. done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu »</TD></TR><TR><TD CLASS="quote">
LOL. if main relay, im thinking the one under the dash? above ur feet? that one i assume....just crawl under there, take a number 10/12 socket (forgot) and just unbolt one bolt holding it up and pull it out , unplug, plug in new one, bolt it back up. done.</TD></TR></TABLE>
So you dont have to pull any panels? I should be able to see/reach it by just looking up the kickpanel?
I heard somewhere it is behind the coin box.
I will take a look then this weekend
From: I told you to wait in the truck in Texas, United States
http://honda.hybrids.jp/tech/p...shtml
The easiest way to relace is to remove the
inner portain from the new relay and insert it into the old case..
Modified by 88DXCRX at 5:59 PM 10/15/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">http://honda.hybrids.jp/tech/p...shtml
inner portain from the new relay and insert it into the new case..
Thanks 88DXCRX
This is exactly what I was looking for. DETAILED INSTRUCTIONS
Thanks to everyone else for your help/replies
Thanks 88DXCRX
HondaDNA93
Jun 5, 2008 09:57 PM
freshly boosted DOHC ZC
Mar 31, 2007 03:37 PM
