84 Prelude will not start
Old Oct 3, 2007 | 05:26 PM
akbrewer's Avatar
Default 84 Prelude will not start
Ok here is the deal. I was given an 84 prelude from the original owner. It has 234k miles on it, and has been sitting for over a year. It will not get fuel to the engine when I try to crank. I have replaced the fuel pump and fuel pump relay, but I still cannot hear the fuel pump working. The car will start if I spray starting fluid in the carb, but then dies when it runs out of starting fluid. I am not sure if there is another relay or fuse I need to replace. A friend of mine who has access to alldatapro looked it up and it said it was the #12 fuse, but my fuse box near the steering wheel only goes to 11. Is there possibly a ground somewhere, or something I can check with a voltmeter?
Old Oct 8, 2007 | 05:48 AM
akbrewer's Avatar
Default Re: 84 Prelude will not start (akbrewer)
Here is an update...
I got a test procedure from alldatadiy, and I checked the voltage where the relay plugs in. I get power from the relay to the battery, however I do not get power from the relay to the fuel pump. Does anyone have any experience replacing/repairing internal wiring?
Old Oct 8, 2007 | 05:52 AM
cb7tougeracer's Avatar
i had that same problem with my 93 accord and it was the fuel filter try that
Old Oct 10, 2007 | 05:06 AM
akbrewer's Avatar
Default Re: 84 Prelude will not start (cb7tougeracer)
Update!
Found the problem! It was a wire short in the fusebox where the relay plugs in.
wtfisvtec??
38
Jun 30, 2024 05:13 PM
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
Vegas H22Prelude Si
Dec 9, 2008 05:50 PM
gsrt nick
Oct 23, 2006 06:43 PM
Sloth
Sep 17, 2002 02:29 PM
