I have a B16A2 already, what else would I need for a B20/VTEC?
Old Oct 3, 2007 | 05:07 PM
Azxster's Avatar
Default I have a B16A2 already, what else would I need for a B20/VTEC?
I am undecided on boost or NA, I just swapped from a D16Y8 to a B16A2 (as recommended by my mechanic and brother) but am not satisfied with the power. I am considering a B20/VTEC build. I know I need new head gasket, timing belt, B20B/Z block, oil line. Would I need anything else like a CR-V/LS throttle body?
Old Oct 3, 2007 | 05:34 PM
redrusch's Avatar
look at all the posts about LS-CRV/Vtec and read them they tell you all the parts you will need, here il make it easy for you
https://honda-tech.com/zerothread/1676914
Old Oct 4, 2007 | 05:37 PM
Azxster's Avatar
Default Re: (redrusch)
I read through that already. But I want to know what parts I need to complete it. One thing I am confused is the throttle body. Which one bolt up correctly? I read the B20 throttle body has issues with the placement of the cable but then is the B16 ok? I know I will need the proper timing belt, short block, vtec conversion kit / oil lines...
Old Oct 4, 2007 | 06:15 PM
H9Omega's Avatar
You have a B16 head already. Use everything that you have from up top and transmission. The only thing your changing out is the block. Get yourself a new vtec oil/ water pump. New timing belt, im assuming your leaving the stock b20 pistons, which is ok. All you need is the b20 block, use all of your other components along with the new headgasket VTEC oil line kit and grab some arp headstuds.
Old Oct 5, 2007 | 08:09 PM
Azxster's Avatar
Default Re: (H9Omega)
How do I check if my head is in good condition? What else do I do other than a compression test. I am unsure if I have a bent valve as it is kind of noisy at 2k+ RPM but pulls fine, doesn't burn anything, and decent fuel mileage.
I already have a new B16 WP, that will work with the B20 right? Would I need new seals/gaskets as outlined in the reliable b20v thread? Is there a recommended vtec oil line kit? If I recall, the Golden Eagle uses VTEC head gasket which is incorrect, should it be vtec or non vtec?
zachattack54
Jan 31, 2008 05:50 PM
SIC_jdm_da9
Jan 21, 2008 08:38 PM
94hatchvx
Oct 3, 2006 06:13 PM
v-tecleta
Apr 19, 2006 07:38 PM
b20vtechatch
Oct 4, 2004 05:44 AM
