dx to mpfi swap
just did a dx to mpfi swap on my 89 civic hatch
got it running today ran good for a little while
then i tryed to move it and it bogged
out like it was skipping time or made i had one of
the plugs in the wrong spot idk
but if anyone knows anything bout
this swap or any ideas what might
be wrong i would appeicate it
yea when i moved it
It bogged down
and then died out
now when i try to start it
it turns over and the main relay
makes a clicking noise
and it doesnt start
It bogged down
and then died out
and it doesnt start
Probably the TPS wiring, did you swap the outside wires on it? If you didn't it will read backwards.
The main relay isn't your problem.
Check your ground wires I had the same problem(start at first,then main relay clicking,no start)after swapping my D16A6 into my car.It turned out in my case to be the ground on the thermostat housing.
i finally figured it out
and im not a noob to hondas
sorry
but it was the eacv sensor
i had the wrong plug hooked up
so i hooked the right one up
now works great
but one question still
does any one know the color of the wires
for the air temp sensor
and i still have check engine lights on
idk
doesnt bog down no more
the tps was right green , red , yellow
i got a fully built sohc for turbo
cant wait to boost it
its been a couple years i n the making
and i think i finally got it right now
sorry
now works great
idk
Ace48
23
Mar 24, 2016 12:44 AM
RobTimmerman
13
Jun 30, 2014 08:21 PM
SpeedMonkeyRacing
Jul 30, 2003 06:15 PM
joshwhe
Mar 21, 2003 10:43 PM
