Need help with my transmission "Pics Inside"
Old Oct 3, 2007 | 04:14 PM
Yolandita's Avatar
Default Need help with my transmission "Pics Inside"
Hello, I need help with my transmission, I need to know what to do to fix it because I need my car ASAP to go to college. My car was driving fine one day my mother had to move my car because I was bloquing her car in the garage and then later in that day when I started my car, it didnt wanted to get in 1st 3rd and 5th gear.
My neighbor told me that it could be the gear shaft under the car " i dont know how to describe it" but he took some pictures,
all i wanted to know is if i need to remove my transmission or if someone can fix it on the car...
The car is a 91 integra LS stock
sorry fore the very dirty parts
The first picture is in neutral,
the second and third picture is in 4th gear, the bar wont get closer to the transmission as close as it it in neutral position, so 1st 3rd and 5th gear wont enter
need help plese
write what yot think!!!!!!!
Old Oct 3, 2007 | 04:40 PM
Uncle Willie's Avatar
Default Re: Need help with my transmission "Pics Inside" (Yolandita)
I bet you will get a request for pic first before you get helped by anyone.
I honestly dont know, so this is a free bump. Sorry i dont know **** about trannys.
Old Oct 3, 2007 | 04:42 PM
Dogginator's Avatar
Daisy... Daisy...
Check the shifter bushings and the engine/transmission mounts. Since it will not go into 1, 3, or 5, it seems as if something may have shifted.
Old Oct 3, 2007 | 06:49 PM
Yolandita's Avatar
Default Re: Need help with my transmission "Pics Inside" (Dogginator)
i posted pics when i created the account, they even closed the thread.
Tahnks about the bushings, is there anything else i should need to know?
Is it possible something inside the transmission got loose?
Can i get out of my mind that i dont need to remove my transmision?
Old Oct 3, 2007 | 07:08 PM
I AM WEASEL's Avatar
It might just look worse than what it is but from the looks of it something is terribly wrong to have all of that fluid, oil, etc. all over your tranny.
Old Oct 3, 2007 | 08:09 PM
Yolandita's Avatar
Default Re: (JDM se-R)
My car always had leaks from the cv shafts seals
i havent had time to replace it, but fluid is always cheked
kim_2_da_chee
Feb 16, 2003 10:52 AM
Rob Dizzle
Jul 1, 2002 07:27 PM
hybrider
May 6, 2002 07:02 AM
