Honda S2000 Honda S2000
400whp Turbo S2000
Old Oct 3, 2007 | 03:55 PM
JG-Fabrications's Avatar
Default 400whp Turbo S2000
Just a couple teaser pics
Finishing up charge pipes, mounting intercooler at the moment
Tomarrow we finish all wiring and tune the car
Dyno chart up friday!
Turbo is T3/T4 57 trim stage 3 turbine
Should make for one very broad powerband
-James
Modified by JG-Fabrications at 4:35 PM 10/8/2007
Old Oct 3, 2007 | 04:15 PM
Agent Zero's Avatar
Default Re: 400whp Turbo S2000 (JG-Fabrications)
****** pants*
Nice!
Old Oct 3, 2007 | 05:03 PM
Francesco's Avatar
need to see more.
Old Oct 3, 2007 | 07:47 PM
m R g S r's Avatar
i'm sure you know this...but aren't turbo's supposed to be braced with heim joints to allow for thermal expansion of the manifold?
Old Oct 3, 2007 | 07:48 PM
m R g S r's Avatar
btw i like the fact that you have the battery and fusebox and (it looks like) the oil filter all in stock location. Is it just a log mani thou, or does it actually have a collector???
Old Oct 3, 2007 | 07:51 PM
140sx's Avatar
once the manifold heats up it will sag and crack because of the weight of the turbo. atleast that is what ive found with my other top mount kits,
Old Oct 3, 2007 | 08:13 PM
matt7746's Avatar
Default Re: (140sx)
thts nice but i love the 2jz
Old Oct 3, 2007 | 09:03 PM
Default Re: (140sx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 140sx &raquo;</TD></TR><TR><TD CLASS="quote">once the manifold heats up it will sag and crack because of the weight of the turbo. atleast that is what ive found with my other top mount kits, </TD></TR></TABLE>
Thus the brace to remove the weight of the turbo from the manifold
Old Oct 3, 2007 | 09:06 PM
Default Re: 400whp Turbo S2000 (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">i'm sure you know this...but aren't turbo's supposed to be braced with heim joints to allow for thermal expansion of the manifold?</TD></TR></TABLE>
I have done many setups with braces very similar to this and never once had a problem
If you know the hood line of the s2k isn't very much higher than the valve cover and a heim joint setup that would properly suspend the turbo is impossible in this situation
The brace has some flex in it, it isn't 100% solid (1/2 inch mild steel tube) but is strong enough to keep the weight off the manifold so there will be no issues
btw this is a very similar brace setup to what I used on my personal setup that was boosting 16psi daily driver 465whp
I never once had issues and my manifold was alot longer which would have made things alot easier to flex
Old Oct 3, 2007 | 09:17 PM
Default Re: (matt7746)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt7746 &raquo;</TD></TR><TR><TD CLASS="quote">thts nice but i love the 2jz </TD></TR></TABLE>
I would take a 400whp s2k with a flat 5k torque curve over a peaky 600 whp setup any day.
Ohh yeah dont forget the extra weight put in the front now makes getting traction harder
The day 2jz owners get their heads out their butts and quit using gt42r+ to make 600whp is the day I will quit ragging on them
You an slap a 60-1 on there and make 600 whp with a usable powerband, ohh wahh if your charge temps go up thats what a proper intercooler is for....
Old Oct 4, 2007 | 04:51 AM
JDM_EM1's Avatar
boost
Old Oct 4, 2007 | 07:28 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JG-Fabrications &raquo;</TD></TR><TR><TD CLASS="quote">
I never once had issues and my manifold was alot longer which would have made things alot easier to flex</TD></TR></TABLE>
cool! hey if it works it works...you have more experience with it than me! just felt like nagging
Old Oct 4, 2007 | 09:47 AM
well you did a good job lol
more pictures up this evening when it is 100% dyno chart up tomarrow
Old Oct 4, 2007 | 04:08 PM
MidwestAutoWorks's Avatar
Log mani?
Old Oct 4, 2007 | 04:24 PM
Default Re: 400whp Turbo S2000 (MidwestAutoWorks)
technically yes but instead of t's I did fit pieces which make a sorta collector that direct the primaries 2 and 3 to the turbo
So it should make slightly better power than a log while being as compact as a log
Old Oct 4, 2007 | 04:32 PM
Another teaser pic to hold you guys over
Instead of putting up full pictures tonight I will do a nice photoshoot tomarrow on the car
Ok I am out till then
-James
Old Oct 4, 2007 | 05:41 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
James, that t3t4 will indeed give that motor a sick power band.... TORQUE anyone???????
Old Oct 4, 2007 | 07:24 PM
Default Re: 400whp Turbo S2000 (S@nt0s)
Das the idea
I am pretty sure this is one s2k owner that wont be going "wahhh I have no trq " lol
Old Oct 5, 2007 | 07:08 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JG-Fabrications &raquo;</TD></TR><TR><TD CLASS="quote">Das the idea
yea people nowadays dont know **** about TORQUE!!!! or just plain jane scared of it
Old Oct 5, 2007 | 06:24 PM
turboeh6's Avatar
I'm in the process of doing almost that same exact setup on my friends AP1. Just wanted to give whoever did the welding for that blowoff valve on the charge pipe some mad props. That's an awesome weld if that is steel pipe, but if that's aluminum (which it looks like it is), that's some serious skill! That is cleaner than almost every robotic tig weld I have ever seen. Hopefully I will get some pics up some of the progress of the project I'm working on. Anyway, good luck with the project and post your numbers and boost levels when you get them.
Old Oct 5, 2007 | 06:25 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 400whp Turbo S2000 (turboeh6)
^^ yes thats aluminum......
Old Oct 6, 2007 | 12:33 AM
Alleykat's Avatar
Looks pretty good.James made my mani aswell.I just wish I had my a/c lines! lol. I need to get em fixed.
Old Oct 6, 2007 | 12:35 AM
Alleykat's Avatar
BTW James can you PM me your phone number.I may need some work done again.
Old Oct 6, 2007 | 05:16 AM
slvrstns2000's Avatar
cant wait till this is my car in those pics
Old Oct 6, 2007 | 09:18 AM
iheartintegras's Avatar
Default Re: (slvrstns2000)
