Lighting HID/Xenon kits, Retrofits and Associated Topics
HID kit into my 91 hatch...all the right stuff just wont work
Old Oct 3, 2007 | 12:37 PM
Playa_FL's Avatar
Default HID kit into my 91 hatch...all the right stuff just wont work
I have the right bulbs (9006) and the kit plugs right in and i bumped up the fuses. Kit still wont work. Anyone know what the trick is? THanks for any help.
Old Oct 4, 2007 | 03:56 AM
operatic's Avatar
Default Re: HID kit into my 91 hatch...all the right stuff just wont work (Playa_FL)
Make sure that the connection that goes into your factory headlight harness is in all the way. If that still doesn't work, sometimes you have to put it in backwards. Also just make sure you put the plugs that go into the ballast the correct way. Also, check to see if you already blew a fuse.
Old Oct 4, 2007 | 12:26 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Your car is saying "noooo please don't install glare bombs inside my headlights"
but really, did you connect them up and check their operation before actually installing and mounting everything and running all the wiring?
Did the kit come with a harness and relays that connect to the car battery, with the factory headlight switch switching the relays?
Old Oct 7, 2007 | 04:16 PM
EFSedan#6's Avatar
Updates?? What kit?? Pictures of setup?
I am interested in picking up an HID kit for my 88 Sedan. OE lamps.
Old Oct 12, 2007 | 02:26 PM
Playa_FL's Avatar
Default Re: (EFSedan#6)
ok no updates just as of yet. I bought a bigger battery fuse its supposed to be 70 amps and mine is 60. I will try switching it around and see if that works also. Thanks for the help, will let you know my outcome! OH yea its a GP thunder HID kit it can be bought at http://www.hid-lights.com
Old Oct 12, 2007 | 02:41 PM
Playa_FL's Avatar
Default Re: (Playa_FL)
Thanks operatic, switching around the harness plug worked. I had to force it in there but it worked! Thanks!!
Old Oct 12, 2007 | 04:29 PM
CarbonizedDX's Avatar
9006 factory plugs are wired reverse (from what I've seen) from the "standard" 9006 hid ballast plugs...
Fo-Do Fanatic
Lighting
20
Jun 15, 2009 09:56 PM
OTiS515
Lighting
35
Apr 6, 2009 10:32 AM
Dr. GSR
Lighting
Jun 7, 2008 05:45 PM
mikeaitken
Lighting
Feb 4, 2008 12:11 PM
