4-2-1 header clearance on hf (or something like that engine)
Old Oct 3, 2007 | 12:15 PM
CRX1.4DualCarb's Avatar
Default 4-2-1 header clearance on hf (or something like that engine)
I have just instaled (or at least tryed to) a 4-2-1 header in my D14 powered CRX.
This engine is just like the hf or any other short block/small journal D-engine.
The header is a oem header from a delsol (D16Z6 engine) and the problem is that it hits the oil pan in such a way that I canīt bolt the primaries to the secondaries or install the header.
I've had the oilpan from a DOHC zc under the one from my engine, and the lower part of it seems narrower with could (should) be creating the clearance problems.
Has anyone had problems installing headers in small d-engines? (d15 for example).
It had a 4-1 header before (oem).
Can I smak the oil pan with a hammer until it gets like 1.5inch clearance?
Will a d16 (z6,a6, etc) oilpan fit in a hf engine with out any other problem?
Old Oct 3, 2007 | 12:30 PM
Crx dude's Avatar
Default Re: 4-2-1 header clearance on hf (CRX1.4DualCarb)
Don't smack your oil pan thats just plain stupid for a part that aint gonna make a differance in your case.
Old Oct 3, 2007 | 01:15 PM
wiZCo's Avatar
Stouts 'n' Scotch
D14? What year CRX is it?
Old Oct 3, 2007 | 01:20 PM
IT GUY's Avatar
Default Re: (wiZCo)
check out his name... he's got carbs and lives in Portugal
sorry I don't have any advice for you
Old Oct 3, 2007 | 01:48 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">check out his name... he's got carbs and lives in Portugal
sorry I don't have any advice for you </TD></TR></TABLE>
I know, I'm curious as to what year it is, maybe it's a 1st gen.
Old Oct 3, 2007 | 02:17 PM
89efDUSTY's Avatar
Default Re: (wiZCo)
Has to be below, only D14 Carbed I know...holy hell Webber that duel carb
D14 Series Engines (1.4 Litre)
[edit] D14A1
· Found in:
o 1987-1991 Honda Civic GL and 1990 CRX (European Market)
§ Displacement : 1396 cm3
§ Bore and Stroke : 75 mm X 79 mm
§ Compression : 9.3:1
§ Power, Torque : 90 ps (90 bhp) @ 6300 rpm, 112Nm @ 4500 rpm
§ Valvetrain : SOHC, 4 valves per cylinder
§ Fuel Control : Dual Carburettor
Old Oct 4, 2007 | 12:16 AM
Default Re: 4-2-1 header clearance on hf (Crx dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx dude &raquo;</TD></TR><TR><TD CLASS="quote">Don't smack your oil pan thats just plain stupid for a part that aint gonna make a differance in your case.</TD></TR></TABLE>
That's exactly the only thing that's keeping me from bolting the header!! It would make all the difference.
The header hits on the oilpan lower part side. My question is can I smack 1 inch on the oil pan side with out messing up with anything inside? (like oil pickup?)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
I know, I'm curious as to what year it is, maybe it's a 1st gen.</TD></TR></TABLE>
Second Gen. It's the same thing as the JDM 1.5x, but with less 100cc and the carburators are regular and not electronic like the 1.5x
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">Has to be below, only D14 Carbed I know...holy hell Webber that duel carb
[edit] D14A1
· Found in:
lolol not a weber double carburator. It has 2 single CV carburators from keihin.
So, Can I hit the oilpan with the all mighty hammer?
Will the oild pan from a y8,z6,a6 fit?
Old Oct 4, 2007 | 12:59 AM
JKGONZALEZ3's Avatar
no you cannot hit your oil pan with a hammer!!!
Old Oct 4, 2007 | 01:06 AM
STREETWERKZ's Avatar
Default Re: 4-2-1 header clearance on hf (JKGONZALEZ3)
PUT THE HAMMER DOWN!
try a different header.
Old Oct 4, 2007 | 03:03 AM
Default Re: 4-2-1 header clearance on hf (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">PUT THE HAMMER DOWN!
try a different header. </TD></TR></TABLE>
lol
ok I won't destroy my oilpan with a hammer... I can see everybody loves EF's a lot over here... it was just a dispensable oilpan to me..
lol
Old Oct 4, 2007 | 08:24 AM
doublethink's Avatar
nah its not just that the oil pan is some sacred thing, BUT if you interfere with the pickup then youll get your header bolted up, and get maybe 40-50 miles and youll hear a really loud sound from under the hood.
motors need oil
granted sometimes youll see a smashed oil pan from going off a crub or something, and sometimes they work fine, but why play russian roulette with your motor?
smart money says try an aftermarket header.
Old Oct 4, 2007 | 08:27 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX1.4DualCarb &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> LOL duh its not, but I was saying to put them on. With a good tune webers can generate tons of power GL
Old Oct 4, 2007 | 08:45 AM
Jonknee's Avatar
Default Re: 4-2-1 header clearance on hf (89efDUSTY)
I smacked my oilpan last year, im losing a cup of oil every 2 months now.
95_red_dc
Sep 22, 2008 10:23 AM
numbnuts22715
Apr 10, 2007 08:23 PM
Elbowpunk
Mar 20, 2006 02:42 AM
junbb1
Mar 24, 2004 05:43 AM
satan_srv
Mar 22, 2004 05:04 PM
