TWM 50mm ITB's on stock 98 spec JDM ITR motor w/ race header
Old Oct 3, 2007 | 10:04 AM
n1_egsex's Avatar
* B A N N E D *
Default TWM 50mm ITB's on stock 98 spec JDM ITR motor w/ race header
my setup right now is 98 spec JDM ITR motor, stock internally, oem itr intake w/ spoon filter, hytech replica race header and 3" exhaust
i ran across a good deal on twm 50mm itb's, and i was wondering if i slapped these on and tuned with crome pro, what should i expect? i'm not looking for peak power gains, but more mid-range and throttle response, which is what ITB's is all about (from what i can understand)
would the 50mm itb's be too big for a pretty much stock itr motor? it rarely gets driven on the streets
Old Oct 3, 2007 | 10:49 AM
IntegraType-R's Avatar
i love mine, make sure your tuning with someone that can tune tps/map and ur able to fool with the tip in. My twm's , i love them, alot of people have mix reviews, but coming from someone who daily drives his car, and has had these same itbs for over 3 months w/o any problem says alot. I actually recommend taking them all apart and caliberating them urself tho, i actually ended up doing that with mine because i couldn't get the plates to open 100%, they do now tho because i took the itbs off and redid them. I also suggest into looking into bigger cams to max the output of the twm's, i use s2s2's and have great results, street wise, i feel the power come quick, overall even with bigger injectors i'm taking in more then 40% of fuel everywhere, so the increase is felt. The car just keeps reving and the power feel on the butt dyno is great. My car idles happily at 900 rpms
Old Oct 8, 2007 | 02:21 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (IntegraType-R)
EL2
Feb 14, 2015 08:44 PM
jerzey908
Sep 26, 2011 07:05 AM
Type_gsR
Apr 2, 2004 01:01 AM
