H22a transmission
Old Oct 3, 2007 | 07:55 AM
Dr.green's Avatar
Default H22a transmission
Im swapping a h22a into my civic and there is two oil lines coming out on the transmission at the speed sensor area.
I cant figure out where they are suposed to be.. i read on the web that they are for the power steering pump on integras or whatever and you can just seal them or loop a hose to both. is that correct? im planning to use the powersteering so i need to know what to do...
[IMG][/IMG]
Old Oct 3, 2007 | 08:06 AM
NirVTEC's Avatar
Default Re: H22a transmission (Dr.green)
No image...
I didn't know PowerSteering in H22 Civics was possible....
Old Oct 3, 2007 | 10:45 AM
hybrid2007's Avatar
Default Re: H22a transmission (::NirVTEC::)
It's deffinately possible
Old Oct 3, 2007 | 10:55 AM
CHK4TIX's Avatar
well, those hoses can just be looped together or blocked off. They are for the speed sensitive steering, and the civics dont have anything comparable to that so you dont need to hook them up. Mine are just looped together on my hatch.
Old Oct 3, 2007 | 11:24 AM
JasonST's Avatar
Default Re: H22a transmission (CHK4TIX)
They're powersteering lines that hook up to the VSS, when the vehicle reaches a certain speed, the pwoersteering will cut out so u don't oversteer. U'll be fine just to loop them off.
Old Oct 3, 2007 | 11:36 AM
Dr.green's Avatar
thanks guys! i'll loop them together!
spraymysol
Feb 20, 2009 07:49 AM
NAEGH22
Oct 28, 2008 03:39 PM
likwidchz
Oct 8, 2007 08:44 PM
