Honda S2000 Honda S2000
f20/f22 piston and engine specs? yes i searched...
Old Oct 3, 2007 | 03:17 AM
fastludeh22's Avatar
Default f20/f22 piston and engine specs? yes i searched...
so i searched and couldnt find anything. i need some internal specs. ie piston pin diameter and type, comepression hight, piston size, deck hight, combustion chamber size, anything you got.
thanks
Old Oct 21, 2007 | 07:44 PM
boostedgsteg's Avatar
Default Re: f20/f22 piston and engine specs? yes i searched... (fastludeh22)
https://honda-tech.com/zerothread?id=1232811
everything u need?
Old Oct 22, 2007 | 02:31 AM
Default Re: f20/f22 piston and engine specs? yes i searched... (boostedgsteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedgsteg &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1232811
everything u need?</TD></TR></TABLE>
thanks, but i knew about that theard. that is the f/h series in the accord/prelude. i was looking for the f20c/f22 thats was in the s2000.
i found some info so far. off the top of my head the f20c compression hight is 1.18. i also have skirt size. rod size, as well as be and se rod bore, and some other specs i had printed from my guy at honda if anyone is interested...
Old Oct 24, 2007 | 08:43 PM
JDogg's Avatar
compression height is 1.171, and the pin is bigger than normal. 23mm i believe.
Roadkiller427
Jan 12, 2009 07:25 PM
hondamark35
Jan 19, 2008 10:50 PM
EBPSI
Feb 16, 2006 07:54 PM
JDM97R
Dec 27, 2003 09:08 AM
