Putting a OEM JDM ITR DC2 wing on a 98 GSR HELP
Old Oct 2, 2007 | 10:01 PM
type-GGSR's Avatar
Default Putting a OEM JDM ITR DC2 wing on a 98 GSR HELP
i have a 98 gsr and i wanna put the JDM ITR DC2 Wing on my trunk. ANy pointers or help on how to do it properly
Old Oct 2, 2007 | 10:17 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: Putting a OEM JDM ITR DC2 wing on a 98 GSR HELP (type-GGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-GGSR &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 gsr and i wanna put the JDM ITR DC2 Wing on my trunk. ANy pointers or help on how to do it properly</TD></TR></TABLE>
Step 1: unbolt your stock spoiler.
Step 2: Bolt on the JDM ITR spoiler.
Step 3: That's about it.
Seriously, the itr just bolts right up. Easy as cake. The only thing is that you will have an extra hole on the right side where the 3rd brake light wiring goes. You can either shave that hole or just plug it with something.
BlueIntegraBoy's Avatar
Remove the acorn nuts from the GSR wing, and install the ITR wing. You'll have an exposed hole from the third brake light wire on your hatch though.
Old Oct 3, 2007 | 12:30 AM
TastyDragon's Avatar
Default Re: Putting a OEM JDM ITR DC2 wing on a 98 GSR HELP (BlueIntegraBoy)
theres a hole similar to tha right side on tha left too cause tha spoiler has some plastic circle clip thing that goes in there. you might have trouble getting that out cause you gota stick you hand back there and squeeze it with pliers to get it out. to cover tha holes i just put electrical tape over them and painted them white.
Old Oct 3, 2007 | 02:17 AM
Doostur's Avatar
Default Re: Putting a OEM JDM ITR DC2 wing on a 98 GSR HELP (CARMA_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CARMA_626 &raquo;</TD></TR><TR><TD CLASS="quote">
Seriously, the itr just bolts right up. Easy as cake. The only thing is that you will have an extra hole on the right side where the 3rd brake light wiring goes. You can either shave that hole or just plug it with something. </TD></TR></TABLE>
Old Oct 3, 2007 | 08:06 AM
Zappythebum's Avatar
Default Re: Putting a OEM JDM ITR DC2 wing on a 98 GSR HELP (Doostur)
Unbolt.. Take off old wing.. Put on new wing... rebolt... PRESTO!
Old Oct 3, 2007 | 10:14 PM
type-GGSR's Avatar
Default Re: Putting a OEM JDM ITR DC2 wing on a 98 GSR HELP (Zappythebum)
well i forgot to add that when i bought the car, it was repainted, and shaved with the stock wing off so i dont see holes or anything
Old Oct 3, 2007 | 11:20 PM
superdat1's Avatar
important bit to leave out. you can either put in new holes or get another hatch
Old Oct 11, 2007 | 01:13 PM
Default Re: (superdat1)
orly? well.. then you can go to an acura dealer for the correct measurements where to drill, or look it up online..
and if thats too much of a hassle for you.. keep it off haha
integra's look clean with no wing imo.
Old Oct 11, 2007 | 02:08 PM
trepteg's Avatar
I installed mine on my 95 integra .. it fit in the same holes , but on the right side , you'll have a hole for the oem wing brake light .. you have to shave it of put a rubber plug in it to avoid the water to enter in your trunk . have you have to get nuts for the bolts on the ITR wing .. that's all !
Old Oct 11, 2007 | 04:07 PM
davidv433's Avatar
check underside of your hatch, there should be two holes on each side close to the edge see if they patched it wit bondo or something. all u got to do is redrill the holes open
Old Oct 11, 2007 | 07:04 PM
SIGJSK's Avatar
unbolt and just put it in haha. not that hard
Old Mar 20, 2008 | 10:48 PM
team1320_k26eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Remove the acorn nuts from the GSR wing, and install the ITR wing. You'll have an exposed hole from the third brake light wire on your hatch though.</TD></TR></TABLE>
i just installed the itr wing on my gsr and it doesn't sit exactly where the oem gsr one does and your right i have exposed holes, the anchor hole and about 3/4 on the hole where the 3rd light led wiring goes.. looks shitty. so i guess i have to send the car to get the holes covered and repaint the trunk. so i guess it not as easy as i thought. had i know it wasn't straight swap i would have sent it out to paint all at once. oh well you live and learn.
Old Mar 21, 2008 | 05:36 AM
iwantturbo's Avatar
Default Re: (davidv433)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidv433 &raquo;</TD></TR><TR><TD CLASS="quote">check underside of your hatch, there should be two holes on each side close to the edge see if they patched it wit bondo or something. all u got to do is redrill the holes open </TD></TR></TABLE>
good idea
Old Mar 21, 2008 | 08:34 AM
vsmdc4teg's Avatar
It is a straight swap. The ITR wing and the ls/gsr wing are the same bolt patterns. Unbolt 1, bolt the other on. Should sit perfectly with only the one hole open on the right side.
If u dont have the holes, look under the trunk and u should see marks where the holes need to be drilled out. Its not hard to do..just drill at the marks.
If ur wing isnt sitting properly, u did soemthing wrong (idk how thats even possible)
Old Mar 21, 2008 | 11:08 AM
Default Re: (vsmdc4teg)
my itr wing sits fine, just not in the same exact spot as the gsr one. mounting points are the same. but like i said i have the anchor and led wiring holes exposed.
b18ctrb
Jul 18, 2016 11:51 AM
vtec8804
Mar 30, 2007 03:31 AM
SSRberni
Apr 22, 2004 11:29 AM
kourjakian
Mar 7, 2004 01:31 PM
geminis2k
Jul 16, 2003 01:05 PM
