flywheel options?h22
Old Oct 2, 2007 | 08:44 PM
BB1LOViN's Avatar
Default flywheel options?h22
should i replace my clutch if im going to get a lighter flywheel? any suggestions on flywheels an h22a1? mainly building the car for daily driving. should i go for a 12lb or 7lb flywheel?
Modified by BB1LOViN at 10:06 PM 10/2/2007
Old Oct 3, 2007 | 01:45 AM
UK_Luder's Avatar
Default Re: flywheel options?h22 (BB1LOViN)
If you've been running that clutch in there for a few years, it would make sense to swap it out while it's all apart.
A lot of people run the Fidanza flywheels in their Ludes. I personally have the Fidanza 5lb one and love it
Old Oct 3, 2007 | 04:43 AM
92hondalude's Avatar
Default Re: flywheel options?h22 (UK_Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UK_Luder &raquo;</TD></TR><TR><TD CLASS="quote">If you've been running that clutch in there for a few years, it would make sense to swap it out while it's all apart.
A lot of people run the Fidanza flywheels in their Ludes. I personally have the Fidanza 5lb one and love it </TD></TR></TABLE>
5lb! damnnn i want one
I have the ACT Prolite its like 7 or 9 lbs i cant remember. I like it alot.
Old Oct 3, 2007 | 05:35 AM
v4lu3s's Avatar
RTFM
How did the flywheel go from 8 lbs at fidanza to 5lbs on the car? was it machined down?
Old Oct 3, 2007 | 07:06 AM
NirVTEC's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">How did the flywheel go from 8 lbs at fidanza to 5lbs on the car? was it machined down?</TD></TR></TABLE>
Ditto that....I don't think Fidanza makes a 5lb'er. I have never heard of one that light before.
I run a ~12lb ACT Streetlite.......The lighter you go, the more revs you will lose between shifts. I personally think the ~8-9lb flywheel is too light.
Check the clutch condition when you do the swap, but be prepared to replace it. One thing I have noticed is aftermarket clutches just don't last anywhere near as long as stock clutches. At 95k miles, when I did my 1st clutch swap, the original Honda clutch was still in great shape. 40k miles later I am on my 3rd aftermarket clutch. Granted one was lost to a blown main seal which sprayed trans fluid all over the 2nd A/M clutch I had in there.
RPS 6puck=20k miles and was eaten alive---destroyed flywheel
Clutchmasters Stage3=15k miles and was ruined by trans fluid-----ruined flywheel
Exedy 3 puck=5k miles so far so good....going to plan on replacing it when I do the Final Drive over Winter.
Old Oct 3, 2007 | 09:18 AM
JT's Avatar
JT
I have recently installed the Fidanza 8 lbs flywheel with ACT HA3-HDSS. Overall quality of the flywheel is good. Crank centric, and timing marks. Perfectly streetable and revs quick. I had to heat up the center a bit before it would friction fit onto the crank, which was not difficult.
HTLuver
12
Feb 26, 2007 01:20 PM
Boostage
Aug 20, 2006 08:20 AM
Maxboost00
16
Dec 30, 2004 11:11 PM
Dc_John
Apr 2, 2004 07:57 PM
Nextelbuddy
Feb 8, 2004 07:56 PM
