Is there a way you can tell if some CTR cams are real or not?
Old Jun 19, 2002 | 02:01 AM
PYITR821's Avatar
Default Is there a way you can tell if some CTR cams are real or not?
My brother is going to buy some CTR cams from someone but I want to know if there is a way to tell if they are real or not. Is there any markings to look for or do you just hope for the best.
Old Jun 19, 2002 | 06:00 AM
Nate B's Avatar
Default Re: Is there a way you can tell if some CTR cams are real or not? (JUNtypeR)
Measure them, not sure what the specs are though...Plus I'm sure other companies make similar ones with the same specs. Good luck though
Old Jun 24, 2002 | 02:42 PM
MisterB's Avatar
Default Re: Is there a way you can tell if some CTR cams are real or not? (KILLERB18)
ok is there any way to tell if the springs and retainers are ctr i am going to buy some used and i want to make sure i am getting ctr and not some auto b16a stuff
Old Jun 24, 2002 | 02:48 PM
sneakychaos's Avatar
Default Re: Is there a way you can tell if some CTR cams are real or not? (cl4show)
why are you buying CTR springs and retainers? just get a set of portflow ones, you'll prolly pay around the same price. If not, wouldn't you rather spend a couple extra dollars to know the motor you plan on revving high will hold? I would, will, and did.
Old Jun 24, 2002 | 02:59 PM
Footwork's Avatar
Default Read and learn...
http://tiiite.b16a.com/VtecCams.htm
Old Jun 24, 2002 | 05:58 PM
MisterB's Avatar
Default Re: Is there a way you can tell if some CTR cams are real or not? (trooth)
well im getting the ctr stuff as a package used, cams springs and retainers for cheeper than just the cams brand new...
saemoonyang
31
Oct 4, 2011 11:45 PM
em1_fox
Aug 13, 2009 10:08 AM
slimcivic95
Nov 4, 2004 10:58 AM
B16Civic93
Oct 29, 2004 10:06 PM
PYITR821
Jun 24, 2002 04:22 PM
