Type SH ecu vs base ecu
Old Oct 2, 2007 | 08:35 AM
kornerk12's Avatar
Default Type SH ecu vs base ecu
The 2 ecus are different by part number.
Type SH - P5P
Base - P5M
However the SH comes with a seperate computer for ATTS, so what is the real difference between the two computers. Can they be interchanged ?
Old Oct 2, 2007 | 08:40 AM
vinuneuro's Avatar
Default Re: Type SH ecu vs base ecu (kornerk12)
Well, a Base ecu obviously won't work in an SH. However, I don't see any reason why an SH ecu wouldn't work in a Base. You'll just have an extra slot that you won't use.
Old Oct 2, 2007 | 01:17 PM
Rob97'SH's Avatar
Default Re: Type SH ecu vs base ecu (vinuneuro)
I was told you can't use an SH Ecu due to the Atts programing (two chips working together) but I could be misinformed.
Old Oct 2, 2007 | 01:19 PM
vinuneuro's Avatar
Default Re: Type SH ecu vs base ecu (Rob97'SH)
I've run my p5p ecu without the atts control unit attached without any problems.
Old Oct 2, 2007 | 06:02 PM
Rob97'SH's Avatar
Come think of it i think it was that the 97 sh ecu wont work with a newer sh 98-01.
Old Oct 2, 2007 | 06:05 PM
lude98SH's Avatar
i always thought it would work just cant use the ATTS computer. That was just what i assumed though. Good question...does anyone know for sure ?
Old Sep 26, 2012 | 11:35 AM
hondaprofessor's Avatar
did you ever find out if this will work? thanks
Old Sep 26, 2012 | 07:33 PM
gstrudler's Avatar
I can't answer for sure, but there shouldn't be any reason you can't use a base ecu in an SH if you don't care about the ATTS. You will have to make sure the years match if it's a '97 or '98 I think; '99-'01 should be interchangeable. Reason being is that emissions things changed in those first years so the wiring and components are slightly different.
elputipuerco
Apr 21, 2016 11:10 AM
morgan@synapse motorsport
Oct 26, 2011 07:01 AM
thao0094
Jul 17, 2007 10:19 AM
kadidle
Mar 24, 2007 04:58 AM
JBurling
May 6, 2002 02:40 PM
