Replacing rings and their chain reaction.
Old Oct 2, 2007 | 12:00 AM
Hardedge's Avatar
Default Replacing rings and their chain reaction.
So it's looking like I might need to replace the rings in my B16A2. However, the motor has 120,000 hard miles on it, so no matter what, I am going to replace the pistons. Now, if needed, I want someone to correct my understanding of something. As per my knowledge, if you replace pistons you don't want to use the new ones with old pins. But, you don't want to use new pins on an old rod. And if you replace the rod, you would replace the bearings by default...Am I looking at an entirely new reciprocating assembly?
Old Oct 2, 2007 | 03:20 AM
NJIN BUILDR's Avatar
Default Re: Replacing rings and their chain reaction. (Hardedge)
The pistons will (should) come with new pins.There is not problem with using new pins with old connecting rods.
PINKFIFFTY
Jan 25, 2015 07:01 PM
Hardedge
Oct 2, 2007 06:25 AM
b18ek670
May 2, 2006 04:54 PM
AlienKrOZ
Apr 27, 2006 08:54 AM
Fatty_1775
Dec 16, 2002 08:33 AM
