motorcycle oil
Old Oct 1, 2007 | 10:00 PM
quicksilver1689's Avatar
i ♥ snails
Default motorcycle oil
Hey what do you guys run in your bikes? I got an 1986 CB700 honda i have 20w-50 castrol actevo, im thinking about going to a synthetic. I was looking at amsoil ( one of the best) but its pretty expensive.
Old Oct 2, 2007 | 04:55 AM
ceas's Avatar
Default Re: motorcycle oil (quicksilver1689)
I use Repsol - no complaints here.
Old Oct 2, 2007 | 06:33 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: motorcycle oil (ceas)
i always used the regular honda jug thats like 15 bones
Old Oct 2, 2007 | 07:28 AM
fatboy01's Avatar
Default Re: motorcycle oil (The Hooligan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Hooligan &raquo;</TD></TR><TR><TD CLASS="quote">i always used the regular honda jug thats like 15 bones </TD></TR></TABLE>
+1.
Old Oct 2, 2007 | 07:33 AM
Targa250R's Avatar
be professional
I just run regular Castrol GTX 10W-40 in my CB750. Ran it in all of my XR250Rs and Civics too.
Old Oct 2, 2007 | 08:40 AM
98JDM_Type_R's Avatar
Default Re: motorcycle oil (Targa250R)
Motul synthetic 15-50w
Old Oct 3, 2007 | 03:20 AM
85's Avatar
85
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">Hey what do you guys run in your bikes? I got an 1986 CB700 honda i have 20w-50 castrol actevo, im thinking about going to a synthetic. I was looking at amsoil ( one of the best) but its pretty expensive. </TD></TR></TABLE>
Ive got into this debate several time and i don't have the time to type out pages of info from my research. According to 3 defferent oil manufacturers, if you have a "DRY clutch" normally found in Ducs you can run just about anything within specs of the manufacturer ie: 10w40
if your bike has a wet clutch, running normal car oil puts you in risk for a slipping clutch due to a chemical called "..." i couldnt remember/find the name and i need to get back to work. check out this link http://vfrworld.com/tex_vfr/tech/oil.htm
use mobile Blue Cap and your golden!
Old Oct 3, 2007 | 06:06 AM
Default Re: motorcycle oil (85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85 &raquo;</TD></TR><TR><TD CLASS="quote">
use mobile Blue Cap and your golden!</TD></TR></TABLE>
i completely agree, ive got in some long winded arguments about this. theres guys on bandit forums also that said synthetic oil has made there clutch slip.
Old Oct 3, 2007 | 11:37 AM
85's Avatar
85
i completely agree, ive got in some long winded arguments about this. theres guys on bandit forums also that said synthetic oil has made there clutch slip.</TD></TR></TABLE>
i'm one of those that often says, "why?" why can't you run car oil in a motorcycle? moto oil feels like car oil. it looks like car oil and im sure it taste like car oil too. so whats different about it? not a whole lot.
synthetic isn't necessarily better lubricating but offers better protection against breakdown.
people need to stop assuming that everything they hear is true.
Old Oct 3, 2007 | 12:20 PM
fatboy01's Avatar
synthetic isn't necessarily better lubricating but offers better protection against breakdown. </TD></TR></TABLE>
+1
Unless you plan on racing at the track (or streets) and keeping the motor near redline, then use synthetic. If you just plan on cruising around, then I think you're wasting money buying synthetic.
Old Oct 3, 2007 | 12:30 PM
zc911's Avatar
Default Re: motorcycle oil (98JDM_Type_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JDM_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">Motul synthetic 15-50w</TD></TR></TABLE>
their semi synthetic is a bit cheaper and nice too. plus it smells good haha
bad-monkey's Avatar
usually motul or mobil1.
Old Oct 3, 2007 | 05:38 PM
oodie's Avatar
Default Re: (bad-monkey)
Repsol 4T Synthtic Blend 10W-40 never had a problem
Old Oct 3, 2007 | 11:09 PM
i ♥ snails
yeah its getting colder out i might switch back to the 10-40, 20w-50 seems to work better in 100+ summers. Yeah friction modifiers can cause wet clutches to slip. I read Amsoil's report, pretty impressed. My friend goes to MMI, motocycle mechanics institute, all there long time instructors swear by amsoil and they been building motorcycle engines for years so im pretty confident.
Old Oct 6, 2007 | 04:06 PM
chitownrida's Avatar
ive used penzoil, (for car 10-40)
no clutch problems,
changed to valvoline 4 stroke moto 20-50 no problems
Old Oct 6, 2007 | 04:32 PM
EngineNoO9's Avatar
people need to stop assuming that everything they hear is true. </TD></TR></TABLE>
that's the stupidest excuse ever. There's a detergent in a lot of car oils that will make your clutch slip. The stuff you need to avoid using is the energy conserving oils. Mobil 1 synthetic works though. I personally use Honda GN4 though since I change oil a lot on the bike. I find these arguments stupid in the first place too. You guys go out and buy an expensive bike then cheap out on **** like tires and oil. wtf! Honda GN4 isn't expensive at all. I'd understand if you were trying to get repsol or motul every time. Don't be a douchebag and get good oil.
Old Oct 9, 2007 | 12:24 AM
i ♥ snails
i dont think the detergents make the clutch slip, from research its the friction modifiers like molybdenum that "can cause" wet clutches to slip. AMSOIL's test's really show you the oils you thought were good and the ones that are good. kind of an eye opener
Old Oct 9, 2007 | 11:26 AM
85's Avatar
85
Default Re: motorcycle oil (EngineNoO9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EngineNoO9 &raquo;</TD></TR><TR><TD CLASS="quote">
that's the stupidest excuse ever. There's a detergent in a lot of car oils that will make your clutch slip. The stuff you need to avoid using is the energy conserving oils. Mobil 1 synthetic works though. I personally use Honda GN4 though since I change oil a lot on the bike. I find these arguments stupid in the first place too. You guys go out and buy an expensive bike then cheap out on **** like tires and oil. wtf! Honda GN4 isn't expensive at all. I'd understand if you were trying to get repsol or motul every time. Don't be a douchebag and get good oil.</TD></TR></TABLE>
***Blue Cap...
Old Oct 19, 2007 | 12:13 AM
bg-33p's Avatar
Where do you guys usually buy your supplies at? ie. filters, washers, oil? best bet ebay?
Old Oct 19, 2007 | 01:56 AM
marmaladedad's Avatar
Local m/c store, directline.com, and Terra Powersports.
Old Oct 19, 2007 | 08:32 AM
Jasper_db1's Avatar
Default Re:
I use Shell Rotella "Synthetic" 5W-40 in my YZF600. I use Motorex 10W-30 in my RC51 since I couldn't find any Maxima oil locally.
I'll likely go with Rotella on all my vehicles @ the next service interval.
Old Oct 20, 2007 | 04:29 PM
bg-33p's Avatar
Default Re: Re: (Jasper_db1)
I have a really noob question, for the crush washer can i use the same size one as i use for a car(ie integra) or is the motorcycle drain bolt smaller than a car?
Old Oct 20, 2007 | 04:35 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">I use Shell Rotella "Synthetic" 5W-40 in my YZF600.</TD></TR></TABLE>
I was using this in my F4i for a while, but it didnt shift as well as with the motorcycle stuff - I've gone to just using Honda bike oil, the price is about the same.
Old Oct 20, 2007 | 06:18 PM
bg-33p's Avatar
Default Re: Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bg-33p &raquo;</TD></TR><TR><TD CLASS="quote">I have a really noob question, for the crush washer can i use the same size one as i use for a car(ie integra) or is the motorcycle drain bolt smaller than a car?</TD></TR></TABLE>
bump
Old Oct 20, 2007 | 07:55 PM
iLude's Avatar
Default Re: Re: (bg-33p)
I've always had good luck with nylon drain plug washers.
Honda's are 10mm. I'm assuming most bikes are similar
