b16a swap done but not power.
Old Jun 18, 2002 | 09:41 PM
mrduque's Avatar
Default b16a swap done but not power.
I have a b16a in my EF.. I don't know what is wrong.. The motor runs good, clutch is good (was able to chirp tires). but the car seems slow.. doesn't seem to get the power to the wheels. can ne one help?? ne suggestions? gonna check the tranny tomorrow.. what should i look for.. I have an S1 maybe gonna swap to a J1 which is better of the two??
Old Jun 18, 2002 | 10:08 PM
Giuseppe's Avatar
Default Re: b16a swap done but not power. (mrduque)
a strawsize exhaust can make it seem gutless.!!
or a clogged cat...check BOTH...
hth
Old Jun 18, 2002 | 10:21 PM
mrduque's Avatar
Default Re: b16a swap done but not power. (Giuseppe)
i'm dropped at the end of the header so I know it's not that.. thinking its something with the tranny or in that area.
Old Jun 18, 2002 | 10:29 PM
Giuseppe's Avatar
if thats the case..check your compression.!
Old Jun 18, 2002 | 10:44 PM
mrduque's Avatar
what should my compression be?? could it have nething to do with transmission?
[Modified by mrduque, 7:45 AM 6/19/2002]
Old Jun 18, 2002 | 10:48 PM
Giuseppe's Avatar
anywhere between 195-210, and make sure that the numbers
are the same across all four cylinders..+/- 5%
good luck...hope u dont have a fucked motor..!
Old Jun 18, 2002 | 11:05 PM
mrduque's Avatar
if my compression is off it's only a matter of replacing the piston rings right??
Old Jun 18, 2002 | 11:07 PM
Giuseppe's Avatar
it depends
it could be a few things that lead to a low compression..
im not a mechanic by trade, so get a pro to check and make
sure the motor is healthy..
g2tegsown
11
Jun 10, 2005 08:36 AM
tncivic-dvsb
Mar 4, 2005 07:14 PM
TheHatchHog
May 9, 2003 10:30 PM
mrduque
Jun 20, 2002 09:06 PM
DuffMan
Oct 18, 2001 03:38 PM
