let me ask you guys a questionnnn
i replaced the clutch, the slave cylinder and the master cylinder 2 timesss!
and bled the whole system. and now theres pressure to my clutch pedal and i could drive the car. but, the pressure doesnt start right away.. the clucth pedal feels funny as if theres still room before the pressure
is there anything else i can do?
and its like i have to press the pedal all the way to the floor for me to get on first gear.
Modified by 94accord718 at 3:45 AM 10/3/2007
I know there is supposed to be a little less than an inch of "free play" before pressing the clutch petal actually starts to disengage the clutch. In this "free play" the pedal will move very easily (no pressure). As far as adjusting your clutch, there are adjusting mechanisms at the clutch pedal, but I don't know much about them.
I was told that I'm missing a plastic bushing that goes over the metal rod that connects the master cylinder rod to the pedal clutch, does anybody know where I can get one.. I checked autozone, strauss.. Etc. And another question.. I know that the brake fluid is not suppose to be empty or even move but mine drops little by little, and I've change the slave and master cylinder.. What else can it be??? Some sort of leak maybe???
Help me out somebody
Thanx
Modified by 94accord718 at 3:40 AM 10/3/2007
Thanx
Surestick
Aug 23, 2006 10:56 AM
Jos3ph
Jan 10, 2006 07:38 PM
