Turbo Vic's 91 std mini me project thread (currently having timing problems)
Old Oct 1, 2007 | 06:11 PM
SQ is the SQUAD's Avatar
Default Turbo Vic's 91 std mini me project thread (currently having timing problems)
my set up consist of
1991 civic std
complete (engine and chasis) 89 si wire harness
89 si d16a6 block/tranny
95 ex d16z6 complete head
stock a6 injectors w/ resistor box
d16z6 timing belt
d16z6 head gasket
megan racing adjustable cam gear
megan racing headers (until i put on the turbo)
msd sci ignintion box
msd blaster 2 coil
stock/new spark plug wires
z6 ngk v power plugs
stock/new rotor
modified 93 accord stock external coil distributor cap
obd0 to obd1 conversion harness
auto p28 odb1 ecu (will convert to standard)
ebay adjustable fuel pressure regulator
complete 93 integra front suspension (need to get civic lca's)
95 integra proportion valve
complete 95 civic ex rear disc brakes
stock cat back exhaust
battery moved to trunk
ebay cold air intake
future plans
parts i dont not currently have are marked with *)
t3/t4 internal gated*
hf manifold w/adapter plate
2.5" down pipe
2.5" intercooler piping
cca intercooler
dsm 450cc injectors
greddy type s style ebay bov
chipped my curreny p28 have it turned with crome
195 lph fuel pump
energy suspension bushing set
i got everything together and the car does run, but it has some serious problems. the idle is a lil shaky and the car smokes. there is gas/water spitting out of the exhaust. (oil and coolent are clean and stay at proper level, so i dont think its a headgasket issue) when the car was running if i pulled spark plug wire #1 or 4 its ran the sam, but if i pulled 2 or 3 it shut off. with some timing adjustments i got it to run solidly on 2, 3, and 4. but when i still pull plug #1 the motor runs the same. i checkd the spark and its sparking good. i am hoping its just a timing issue. i got the crank set to tdb (single white mark) and i set the head to tdc with the stock z6 cam gear (timing marks lined up). i threw on the megan adjustable cam gear. i got the motor to run best with the cam ger advanced all the way and the distributor all the way twords the firewall. i cant get a good view on the crank pully with the timing light, plus i really dont know how to use the light so thats out. with everything advanced the car idles 96% correctly, but i dthink i still have a slight misfire on cylender #1. i have had this issure before i installed the msd setup. i was having coil problems so i threw on the msd i had sitting around. i was told i should get a fuel pressure regulator and turn down the pressure. i had an ebay fpr so i went to throw it on but i had to buy an adapter so i can hook it to my fuel rail.
any help would be appreciated. you can im me on aim SQ is the SQUAD or you can email me voweeks@comcast.net if your in the boston area feel more then welcome to come by and help
my digi cam **** the bed, so no pics for now
Old Oct 2, 2007 | 07:43 AM
got the car running and decided to pull the plug of injector #1, and the car ran the same, so i know for a fact that it has something to do with injector #1. i know its got air, fuel and spark.
first thing today i put back the pm6 and the a6 distributor. the car ran the same. after i undid that i swapped the injector 1 and 2 around and 1 was still miss firing. i changed the resistor box and it was still the same. then i got another injector clip, ran wires straight to the resistor box and ecu, it was still the same.
i removed the #1 spark plug and cranked the motor, a lot of air was blowing out the hole at a really high rate so i think i got decent compression. i think i may possable have a bent valve, just dont know how to really check for that. is it possable i just need a valve adjustment? please give me some ideas on things to check
Old Oct 2, 2007 | 10:00 AM
ef-hatchcrap's Avatar
Default Re: (SQ is the SQUAD)
I dont think you have it in time correctly you need to set the crank a tdc single little white mark on crank pulley then you need to take that adj cam gear and set it to stock how it cam in the box then put the clylinder head in time and adjust the cam gear later on a dyno while you are getting it tuned.
Its going to to run like **** and not make the right power until you get it tuned the proper way
Old Oct 4, 2007 | 09:01 AM
did a compression test todat and #1 was 0, #2 was 190, and 3 & 4 where 220
so i am going to assume its a valve problem going to pull the head
Old Oct 6, 2007 | 08:57 PM
ok, i guess i have a problem with #1, iam goin to change all the valves with one from another hea and send it out to get cleaned, decked and sealsw/ 3 angle valve job. but should i be worries about #2 only being at 190 while 3 and 4 are at 220?
Old Oct 25, 2007 | 07:53 PM
lilhonduh91's Avatar
Default Re: Turbo Vic's 91 std mini me project thread (SQ is the SQUAD)
Hey If you could get some pics up that be sweet... I looking to do a boosted Mini Me... Any info on how much boost your running would be sweet!!!!
Old Nov 10, 2007 | 02:10 PM
i finally had time today to get the timing set up with the new head on. started up pretty good, idles good. but when i hooked up the radiator and filled the cooling system all hell broke loose. i guess the head gasket dident seal good or is on wrong. at first i had a leaky valve cover gasket (used). when i filled the water i could see the water mixing with the oil comming through the valve cover gasket. ill have to pull the head AGAIN and this time i am going to get a cometic head gasket. i also compression thested the motor and got 210 accross the board
SQ is the SQUAD
Dec 12, 2008 05:36 AM
superhatchbackbros
Oct 23, 2006 09:07 AM
Stoich
14
Apr 16, 2004 05:38 AM
