Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
LS SWAP, TURBO STUFF, WISECO, EAGLE, OEM, B16 HEAD, LS/VTEC CONVERSION AND MORE
Old Oct 1, 2007 | 05:51 PM
HickamHatch's Avatar
Default LS SWAP, TURBO STUFF, WISECO, EAGLE, OEM, B16 HEAD, LS/VTEC CONVERSION AND MORE
FOR SALE: WILL ACCEPT REASONABLE OFFERS!!! ALSO INTERESTED IN TRADES
Want to trade for: Aeromotive elmininator pump, fuel filter with -10an fittings, Lenso 13" VPD wheels, 44mm Tial wastegate, Tial 50mm BOV, Fuel pressure gauge, newer greddy 52mm oil temp gauge
1996 LS SWAP has about 90k on motor. converted to OBD1 and has P75 ecu. Had 60k on it when I got it and drove on it for a year. Has Crower valve springs and titanium retainers, ARP head studs, and Hondata look-a-like intake manifold gasket. Everything is here except the rear motor mount and the boot on passenger side axle is ripped and needs grease. I know the motor runs, took it out when I sold the shell. Comes with Clutch Specialties 6puck sprung clutch. LEGIT MOTOR WITH VINS, friend got it from junkyard then I bought it from him. Comes with engine harness. Drop in swap for any 92-95 chassis. Replaced timing belt, HG, and tensioner 15k ago.
$1500
GE 84mm LS/Vtec conversion headgasket NEW NEVER USED $90
AEBS LS/Vtec conversion head studs $95
NEW LS/Vtec conversion oil line and sandwich adapter line is new, sandwich adapater is used $90
LS Tranny has Phantom Grip LSD, needs case $300
NEW OBX GSR LSD new set of bearings pressed on, LSD never used $400
Chipped p06 ECU perfect for hondata, uber, crome, etc $100
Gauge cluster dual gauge pod mounts (2) 52mm gauges around the gauge cluster in a 94-01 Integra $30
Catchcan for your battery tray cut down your stock battery tie down hooks and it comes with a catch can brace, can add fittings or whatever you want. was using regular rubber hose, but -AN line can also be used SOLD
Can also custom fabricate a catch can with any dimensions you want. Just PM me
RC 550cc injectors don't need a resistor box for those that are asking $200
LS oil pan tapped for return line $40
Fast turbo oil feed line NEW $40
94-01 integra
LS gauge cluster, manual with 130k. $70
glove box $20
heater core $20
black shifter console $20
black cloth armrest $20
LS crank with spun rod bearing $15
12" L5 solobaric sub in good size box, fit perfect in the back of my hatch and Kicker 750.1 mono amp. Only used for a month then took it out. Have everything to hook it up $300
Modified by HickamHatch at 7:32 PM 10/22/2007
Old Oct 3, 2007 | 08:49 PM
Default Re: LS SWAP, TURBO STUFF, WISECO, EAGLE, OEM, B16 HEAD, LS/VTEC CONVERSION AND MORE (HickamHatch)
UP
Old Oct 5, 2007 | 05:05 PM
GSaura's Avatar
bump for some good parts
Old Oct 6, 2007 | 09:23 AM
more pics added
Old Oct 6, 2007 | 11:08 PM
sold some stuff so less pics for the slow guys
Old Oct 8, 2007 | 11:17 AM
***** goin quick
Old Oct 11, 2007 | 04:22 PM
bump
Old Oct 14, 2007 | 10:00 AM
up
FULLYBUILT2.0
Jan 27, 2009 07:44 PM
vtecspeed1320
Mar 29, 2008 07:34 AM
vtecspeed1320
Southeast (Sales)
22
Mar 27, 2008 04:01 PM
HickamHatch
31
Oct 8, 2007 03:09 PM
