Advantages of a neon rad over stock???
Old Jun 18, 2002 | 09:16 PM
Red_Si's Avatar
Default Advantages of a neon rad over stock???
What are the advantages of putting in a neon rad??? does it flow any better than stock??? is it smaller, what?
Old Jun 18, 2002 | 10:53 PM
Giuseppe's Avatar
Default Re: Advantages of a neon rad over stock??? (Red_Si)
yes its smaller, it has the same flow...
no overheating noticed....
advantages: its shorter, good for turbo
the neon rad uses the stock passenger side
upper rad support...
bolts up nicely, ( when u remove most of the shitty rubber
busings)
u need a filler neck though...
good luck!
and its a neon rad with NO ac.!
Old Jun 18, 2002 | 11:11 PM
Giuseppe's Avatar
Default Re: Advantages of a neon rad over stock??? (Giuseppe)
credit goes where credit is due..
Jared is the originator of this mod
heres a link that might be of use.:
https://honda-tech.com/zerothread?id=181371
good luck!
Old Jun 19, 2002 | 04:52 AM
Charlie Moua's Avatar
Has there been any sign on over heating? and does it work as well as the stock radiator?
So i only use both(top & bottom) of the left side radiator mounts to hold it up?
Old Jun 19, 2002 | 05:45 AM
Giuseppe's Avatar
Default Re: Advantages of a neon rad over stock??? (Charlie)
i have seen no changes whatsoever to coolant temps.. i have no AC btw..
i used the stock upper rad support and
could have used the lower passenger rad support but opted to
make two brackets to rest the rad on instead...
hth
Old Jun 19, 2002 | 06:34 PM
Red_Si's Avatar
how would it work with a/c on my car??? would the temps still be ok?
Old Jun 19, 2002 | 07:09 PM
Giuseppe's Avatar
all depends on where u live and if youre blasting it on COLD
24/7, its a rad man, it does what its meant to do....
mikep_95133
May 10, 2009 03:14 PM
acmoc
Nov 3, 2008 06:03 AM
EF9ZC
Oct 2, 2005 09:54 AM
speedaholic92
Oct 28, 2002 04:31 AM
