wiring harness questions!!!!!! please help!!!
Old Oct 1, 2007 | 03:19 PM
91tealhatch's Avatar
Default wiring harness questions!!!!!! please help!!!
ok well my hatchback cought on fire a while ago. it happened at the battery so the cabin harness is toast, as well as my engine harness. my question is: my car is a DX with A/C and rear defrost and i was wondering if i could use a SI harness since i have to change the entire harness. will it all plug and play for the most part except for the sun roof which i will leave hanging.
thank you very very much for your help!!!!!!!!!!!!!
Old Oct 1, 2007 | 06:57 PM
konka's Avatar
Default Re: wiring harness questions!!!!!! please help!!! (91tealhatch)
yes it will fit. but the only thing is that on a dx u have 2 injectors and on a si u have 4 injectors. u would need to get the complete intake manifold for the si modle and the si ecu( the code is pm6 for the ecu). everything else will just plug right in. hope this helps.
Old Oct 1, 2007 | 09:04 PM
Default Re: wiring harness questions!!!!!! please help!!! (konka)
yea well im putting a b series in as well so it will be ok. thanks!!!
Old Oct 2, 2007 | 01:33 PM
anybody else for input?
Old Oct 4, 2007 | 08:06 PM
Old Oct 4, 2007 | 08:16 PM
crx-b16's Avatar
well if your putting in a b series in your rex and think wire are bad umm if I was you go with http://www.rywire.com and they make you a new one with what you need...if you want it done right go with them or call them for questions...Ryan helped me out alot on my Swap and helped me with Reff...or send me a tell...
Old Oct 4, 2007 | 08:25 PM
Default Re: wiring harness questions!!!!!! please help!!! (crx-b16)
i can wire it for a b swap, i just need to know if a si harness will plug in and work
Old Oct 4, 2007 | 08:33 PM
crx-b16's Avatar
ya if you go with Obd0 but if you go with Obd1 which I think you should runns better and cleaner... but thats all up to you yes it will work fine
Old Oct 4, 2007 | 10:33 PM
Fuzzy Rhubarb's Avatar
I know that the A/C harness is separate from the engine harness on a DX. At least mine was. Unless SI harnesses come with A/C built in (no clue), then you will have to get the separate A/C harness too.
Old Oct 4, 2007 | 10:42 PM
Hamstr323's Avatar
Default Re: wiring harness questions!!!!!! please help!!! (Fuzzy Rhubarb)
yes you can but you need the WHOLE! thing front to back
Old Oct 4, 2007 | 10:54 PM
Default Re: wiring harness questions!!!!!! please help!!! (Hamstr323)
Isn't the engine harness completely separate from the cabin harness?
Old Oct 4, 2007 | 11:01 PM
yea but when it cought on fire it burnt the conector in the shock tower where both harness's plug in, so i need both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">yes you can but you need the WHOLE! thing front to back</TD></TR></TABLE>
so from the head lights to tail lights? or just engine and cabin? thanks!!!
Old Oct 4, 2007 | 11:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tealhatch &raquo;</TD></TR><TR><TD CLASS="quote">yea but when it cought on fire it burnt the conector in the shock tower where both harness's plug in, so i need both.</TD></TR></TABLE>
I don't know how big said connector is, but if it is just a small number of wires/pins that are damaged in the cabin harness, then get the SI engine harness and then just repair what was damaged elsewhere. IMO, that beats replacing EVERYTHING.
Old Oct 4, 2007 | 11:20 PM
look at the link in my sig. it has the pics and damage
Old Oct 4, 2007 | 11:23 PM
its the conector that hooks the engine harness to the cabin harness
Old Oct 4, 2007 | 11:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tealhatch &raquo;</TD></TR><TR><TD CLASS="quote">its the conector that hooks the engine harness to the cabin harness</TD></TR></TABLE>
You could get the SI harness and cut off the burnt cabin harness and solder on a new one instead of replacing the whole harness. Though you might want to play it safe and replace the cabin harness too. You very likely might have some sort of short somewhere in it. ECU might be fried too.
Old Oct 4, 2007 | 11:33 PM
im doing a new swap, im going b series.
Old Oct 5, 2007 | 12:02 AM
Hamstr323's Avatar
so from the head lights to tail lights? or just engine and cabin? thanks!!!</TD></TR></TABLE>
yup
BlendedEM1
Feb 13, 2011 07:06 PM
tijuanavtec
11
Dec 8, 2009 04:32 PM
aug
Jan 8, 2008 10:39 AM
yz125rider21
Feb 5, 2007 12:13 PM
Argetnia
Apr 7, 2005 11:54 PM
