door locks
I have a 91 Accord LX. The drivers door is stuck shut with both power lock and handle latches in working order. The local honda dealer says it is a broken door jamb latch and they can not fix it without destroying the interior door panel. Anyone know how I can get this door open with out destroying anything?
remove the frt seat.. it will give you better access on removing the door panel without destroying it..
http://techauto.awardspace.com/doorproblem.html
hope this helps
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clttt2 »</TD></TR><TR><TD CLASS="quote">I have a 91 Accord LX. The drivers door is stuck shut with both power lock and handle latches in working order. The local honda dealer says it is a broken door jamb latch and they can not fix it without destroying the interior door panel. Anyone know how I can get this door open with out destroying anything?</TD></TR></TABLE>
I hate fixing those. You have to drill out the door latch and hope you get it in the right spot. But yes you risk breaking the door panel getting it off. I've been lucky and just broken the clips.
