-=| '94 Accord Automatic Tranny issuses |=-
Old Oct 1, 2007 | 07:47 AM
DnB TeK's Avatar
Default -=| '94 Accord Automatic Tranny issuses |=-
I'm working on a Accord with a tranny problem. The symtoms are when putting the car into D4 and accelerate it doesn't go anywhere. Like it won't go into first gear or something. So I put into D1 or D2 then it's able to go, then shift into 3rd and 4th gear.
Steps I have taken that I thought would solve the problem, I replaced the tranny with another and it does the same thing.
I'm thinking there might be a problem with the TCM, maybe even the ECU. It might a selenoid issuse.
Let me know if you ran into this problem before.
Old Oct 1, 2007 | 09:58 AM
Duane_in_Japan's Avatar
Default Re: -=| '94 Accord Automatic Tranny issuses |=- (DnB TeK)
slightly educated guess, if it works manually, 1, 2, etc then I suspect a TCM / ECM. It should at least take off in 3rd for limp home mode, can you pull any codes, can the PRNDL switch be bad in D4? No R either. Can you go from 1 to 4 right away once you are moving, will it shift through all gears then, will it only go once you drop it into 1.
LittleBlueAccord
Feb 29, 2008 12:34 PM
johnnyaccord99
Jun 26, 2007 04:02 PM
skiptomylou
Mar 8, 2006 04:53 AM
djdestruction
Nov 15, 2005 03:08 PM
chipster
Dec 17, 2003 07:07 PM
