Question about fuel injectors
I just rebuilt a b18c1 for my 94 Integra gsr. Until I can get down to the dyno, buy some rc or precision injectors and have my hondata S200 properly tuned (which should be very soon) will similar year 2.2L Accord injectors give my car enough fuel for the time being? The setup is gsr head w/ Blox Tuner B cams (stage 2 I think), springs/retainers, mild port/polish, and gsr block w/ ITR pistons and obviously intake, hytech replica header, and 2-1/4-1/2" exhaust (still kicking around what size we will make.) If anyone has tried running bigger oem Honda injectors please let me know how they worked out. Once again, this is just a temporary fix until I am able to make the 3 hour drive to get tuned.
The f22 injector is no larger then the stock bseries 240cc injector.
1997-2001 Honda Prelude injectors are larger. (290cc)
1993-1996 Honda Prelude injectors are low impedance and require a resistor box but are larger. (340cc)
Thanks, so I would need to find some H22 injectors and modify the plugs on the injector if I didn't want to change plugs on my wiring harness correct?
