Are all B-series IACVs the same?
Old Oct 1, 2007 | 01:29 AM
jumai182's Avatar
Default Are all B-series IACVs the same?
I have a '99 b16a2 that I suspect the IACV is going out. My friend gave me a replacement but it looks different than the one that is on my car. My question are all IACV for b series motors compatible with each other?
I tried searching but couldnt find anything.
The one currently on the motor looks like this one. It has a longer black barrel. Not the actual picture.
The replacement my friend gave me looks just like this one.
Old Oct 1, 2007 | 01:43 AM
92hatchboi's Avatar
Default Re: Are all B-series IACVs the same? (jumai182)
are you sure thats for b series. if it bolts on then it works,
Old Oct 1, 2007 | 01:46 AM
jumai182's Avatar
Default Re: Are all B-series IACVs the same? (92hatchboi)
Im not. My friend gave it to me and told me that it was a bseries iacv. I havent bolted it on yet but, it wouldnt screw anything up electronically would it?
Old Oct 1, 2007 | 04:29 AM
pgpbubble's Avatar
Yes; theyre are two different B-Series IACV's. Thats why on aftermarket intake manifold it has both bolt hole provisions.
Old Oct 1, 2007 | 06:22 AM
97Ej6mike's Avatar
If i didnt know any better.... that first pic looks exactly like a Z6 IACv, and thats for a B-series?
Old Oct 1, 2007 | 06:26 AM
Luserkid's Avatar
Default Re: (97Ej6mike)
Bottom one is more then likely GSR as they have longer IAC's. First pic looks like it could be B16 or D series.
Old Oct 1, 2007 | 07:47 AM
gsr336's Avatar
i say as long as it bolts up and sensor goes in correctly you should be fine... im on a b18c1 and using one off a f22 97 accord
Old Oct 1, 2007 | 11:30 PM
jumai182's Avatar
Default Re: Are all B-series IACVs the same? (gsr336)
Ok I installed it. It fits fine and it even helped fix some problems but at the same time they turned into new ones. *sigh*
j_civic
Nov 26, 2008 07:38 AM
jimmyisback
Honda Civic (2001 - 2005)
Oct 28, 2008 03:04 PM
gc05qns
Aug 2, 2006 03:58 PM
