Suspension & Brakes Theory, alignment, spring rates....
GSR Rear Brakes
Old Sep 30, 2007 | 10:51 PM
CB7Tuner915's Avatar
Default GSR Rear Brakes
I recently Purchased a EG with a GSR rear Disk Conversion But the Handbreak does not work do I need to buy a GSR Brake Cable Or any other kind? Any Info would be greatly Appriciated...And how hard is the install?
-Rey
Old Oct 1, 2007 | 10:43 AM
Targa250R's Avatar
be professional
Default Re: GSR Rear Brakes (CB7Tuner915)
What model of Civic? 2dr/3dr/4dr?
If you need cables, the correct cables for a 3dr Civic are from a '92-95 EH3 Civic Si hatchback. The correct cables for a 2dr/4dr Civic are from a '94-95 Civic 2dr EX-ABS, '94-95 4dr LX-ABS or '92-95 Civic 4dr EX.
'94-01 Integra cables (any trim level) will work, but the lengths may not be spot-on.
Old Oct 1, 2007 | 12:20 PM
Default Re: GSR Rear Brakes (Targa250R)
3dr VX 1992 Civic Hatch
So would honda be the best spot to get the cables?
Old Oct 1, 2007 | 03:45 PM
Targa250R's Avatar
be professional
If you have a hatchback, the correct cables are from a '92-95 Civic Si 3dr. You can use the Integra 3dr cables as well.
If you want them new, you're limited to OEM Honda AFAIK.
Otherwise, you can source them used from salvage yards.
Old Oct 1, 2007 | 09:39 PM
Thanks for the help man
and idea on how to install the cables?
Kilpuri
Feb 24, 2009 11:42 AM
LUiS010606
11
Dec 15, 2008 01:24 PM
jus_spooln_wicha
May 14, 2007 12:40 AM
lv2exl8
Northwest (Sales)
Apr 17, 2006 11:01 PM
