1994 honda civic v-tech swap ecu wiring help needed.
Old Sep 30, 2007 | 09:26 PM
cantbetouched24's Avatar
Default 1994 honda civic vtec swap ecu wiring help needed.
Hows it going everyone ,
Im having a problem and need some help 94 honda civic. i switched my car from a non v-tech to a vtec . the vtec engine has two extra concectors which comes out to 3 extra wires already did the running of the wires and found out what part of the wiring harness that connects to the ecu they need to go to.. the problem i am having is how do you wire the wires the three extra to the ecu ?? i want to put them in the connector in the right areas and in the area they go the connect is empty which is good except i do not have those little metal pins that are in the connector that connect up to the ecu and make it work .. can someone please either tell me where i can get those little metal pieces in the concetor . or a connector that has them all already or any help one how you would wire it up or wired it up would be appreciated . Thank you .
Modified by cantbetouched24 at 8:08 PM 10/1/2007
Old Sep 30, 2007 | 10:43 PM
89D15CRXDX's Avatar
Default Re: 1994 honda civic v-tech swap ecu wiring help needed. (cantbetouched24)
Chode...not vtech, VTEC. Can you not read the valve cover? Also, if you want those wires to go into the connector, you'll need to either get a junked harness, or find some of the pins that the ECU plugs use and splice onto those. Luckily for me my car's a 92 and the engine bay harness was already pre wired for it. Plus I had an 89 CRX for a donor harness.
Old Mar 20, 2009 | 12:38 PM
motorrj20's Avatar
New User
Hey what's up all I have a 94 civic dx I bought that has a 90 zc 1.5 motor and I have a daul cam motor that came out of a 97 civic does anyone know what I have to have to do the swap I still have the 94 ecu and I think all the obd1 harness
EGCIVICKING95
Aug 30, 2011 05:03 AM
SOLEpassion
Mar 27, 2010 04:30 PM
Bseriesy0
Sep 21, 2004 10:14 AM
MM's94Civic
Jun 30, 2004 08:59 PM
EgitR
Apr 7, 2004 04:31 PM
