Chicago & Illinois: FS/FT WTB, October 2007
The build was done less than 5k miles ago and everything was purchase new except DSM 450's. Never been boosted yet, this setup could easily handle 20psi 350hp turbo kit. And should last a long long time. The only reason I am selling is because I decided to go another route and go ALL moror GSR instead.
$1500 obo. For another $500obo I will include the LS tranny (rebuilt w/ new syncros about 20k ago) w/ ACT 9.5lb Flywheel and Stage 1 Excedy Clutch.
This is the list of parts used for the build. It is running great (burns no oil etc..150psi accross) Any questions PM me - My name is Derek. Thanks
Probe Industries Forged turbo pistons 9:1 81mm
Eagle H-beam rods ARP 2000 3/8
ACL main bearings
ACL rod bearings
ACL thrust washer
ARP Rod Bolts
ARP Main Studs
ARP Head bolts
Micropolished knife-edged crank at 29lbs
STR block guard
Goodyear Gatorback timing belt
OEM tensioner from omalleys(honda)
OEM valvetrain from omalleys(honda)
OEM waterpump from omalleys(honda)
OEM ls camshafts from omalleys(honda)
OEM rockers from omalleys(honda)
OEM valve cover gasket, gromets, tube seals from omalleys(honda)
New thermostat
Cometic head gasket
Felpro oil pan gasket
Vision cam seal
NGK spark plugs
Overbored throttle body 66mm
Exedy stage 1 clutch w/ pressure plate
9.5lb ACT flywheel
Fresh Hone
Ready for the tubo kit of your choice!
Modified by Honda_Fanatic at 6:24 PM 10/20/2007
ACL main bearings
ACL rod bearings
ACL thrust washer
ARP Rod Bolts
ARP Main Studs
ARP Head bolts
STR block guard
New thermostat
Cometic head gasket
Vision cam seal
NGK spark plugs
9.5lb ACT flywheel
Fresh Hone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">Hey you're not Frank</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle »</TD></TR><TR><TD CLASS="quote">what the hell?</TD></TR></TABLE>
Is everyone gonna be OK if I start this thread? Seems like alot of people are concerned! Just thought it was about time it got started. 5hrs till October officially begins.
does anyone need a fudgin beater???
I have a 4 door eg which needs some tlc but drives fine. for 700
Pm me if interested.
winter is comming guys
<FONT SIZE="3"><FONT COLOR="red">Let Me Paint Your Valve Cover.
Here is my Latest Creation.</FONT></FONT>
<FONT SIZE="2">Freshly Painted Grenada Black Pearl VC w/ Risning-Sun Spark Plug Cover</FONT>
Here is my Latest Creation.</FONT></FONT><FONT SIZE="2">Freshly Painted Grenada Black Pearl VC w/ Risning-Sun Spark Plug Cover</FONT>
i have a mint set of 89-91 civic/crx tein basics
they will fit most other hondas with ef or DA forks.
they are mint.
500 obo
600 obo with K sport LCA's
they are mint.
500 obo
my built boosted hatch FS/FT
heres the full link http://www.hondamarketplace.co...06361
<center>
</center>
Modified by crawlin at 6:46 PM 10/8/2007
<center>
</center>
For Sale:
1. 2001-2003 Civic DC Sports front strut bar(Polished)$50
2.92-95 civic guage clusters (2) (107,000 and 67,000 miles) no tach!!$30
3.OEM Civic SI front strut bar.$45 Pending!!
4.Tein S-Tech lowering spring 5 months old with stock struts from 95 Civic.$100
5.SuperVision 9006 8000k(Diamond White) H.I.D Bulbs with power conectors ONLY!! in box. I know they will fit EFs and Integras and also Scion TCs because they came off my girls ride.(4 months old) $60
6.99-00 Civic SI Rear Sway Bar with all hardware except endlinks. $50
7. 92-95 Civic OEM front corner lights. $15
8. 92-95 Civic OEM whole center console from the cup holder to the e-brake(Blue). $20
LOCAL PICK-UP ONLY!! NOT WILLING TO SHIP!!!
f/s 15in 4x100/4x114.3 Mugen silver RG. its got 205/50/15 snow tires on it mount and balance really good no bents!
One of the rim got shipping damages on 3 of the spokes
700 Firm
700 Firm
WTB:
-turbo d-series parts
[ie. chipped p28, FMIC, piping with bov welded, DP, hf manifold, turbo, oil lines]
-SI-R 96-98 front lip
FS:
-front 2 civic springs and shocks off a 97 coupe
-d series oem clutch and flywheel [85k on them both, still usable]
FS:
FS:
-JDM B16A Block, Crank & Mains $100 Or Trade for B18B Block.
-96' LS complete Cylinder head minus cams & dizzy $100.
WTB:
-94-97 Integra Front bumper (good condition)
-DC2 Black Door Panel Handle Cup Piece.. (the piece you grab to close your door from inside the car)
WTB:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project-[R »</TD></TR><TR><TD CLASS="quote">]PM'd you 92b16si</TD></TR></TABLE>
replied
replied
built head package which consists consists of a built ported gsr head with toda valvetrain, toda spec b cams, type R IM/TB (made to fit gsr head), bdl fuel rail, rc 310 injectors with clips, and brand new skunk2 (pro series? id have to check) cam gears. Ill also throw in a set of b16 pistons (still on b16 rods) for a little more comp and a brand new b-series Rage/Hytech Tri-Y replica header. I paid more than 1600 plus shipping for this a few weeks ago, Im looking for 1300 or best offer
I need the following for a b18b
-IAC unit
-MAP sensor
-passenger side tie rod
-stock air box
I have a AEM CAI I would be willing to trade if interested and maybe some Intrax springs. I need the IAC more importantly. If your in the Aurora/Naperville area please let me know. please email me for quick response.
tommycho@gmail.com
Thanks
Tommy
-IAC unit
-MAP sensor
-stock air box
tommycho@gmail.com
Thanks
Tommy
FS: '03 RSX Type-S Desert Silver Metallic in Southern WI
http://www.hondamarketplace.co...04010
PM me with questions.
