1992 eg with ls/vtec on boost for sale
i am the second owner of this car, there is no rust on the body of this car. it was manufactured in canada. yes the body has 350,000 miles on it but front and rear suspension is from a 1998 acura integra gsr, the engine has 1000 miles on it(fresh rebuild) it has a 1998 gsr tranny with a b18a1 block with stock ls pistons and rods with a b16 head. also has custom 2.5inch exaust to the back and best of all a/c still works wonderfull. if you want piks email me at ckalj123-at-aol.com. all she needs is a paintjob and some tints and you will be set.
p.s is comes with a chiped p28 ecu with 2 chips to run the 450cc injectors on up to 30lbs of boost and an all motor skunk 2 chip .
if you want to make offers just email me for piks and we'll talk from there.
i am located in south fla.
also it has h&r coilovers with tokico blue shocks. i rides like a pillow. the car is slammed on some 16 inch dark bronze rims. has safc installed, amber corners with hids and the jdm foglights installed. also rear si style red clears. rear duckbill and front lip.
and has an exedy 8lb fly wheel with a exedy pressure plate and a 6puk sprung act clutch which has less than 6kmiles on it.
1993acuraintgralsvtec
Nov 30, 2004 09:13 AM
chet
May 10, 2004 11:24 AM
