94 accord help
check for spark...if none swap main relay...Im assuming your battery is fine and your starter was also????? GL there's a thread in the FAQ on how to do it if you dont know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! »</TD></TR><TR><TD CLASS="quote">check for spark...if none swap main relay...Im assuming your battery is fine and your starter was also????? GL there's a thread in the FAQ on how to do it if you dont know</TD></TR></TABLE>How do i check for spark? Thanx
pull out a spark plug wire...point it at the manifold..have someone turn the key...you should see it arcing or headr it going towards the manifold which you are using as a ground..bam spark...if you donk have none youll just hear your motor turning over
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrZFiNeSt »</TD></TR><TR><TD CLASS="quote">The firing order should be 1-3-4-2</TD></TR></TABLE>Yeah but how does it look on the dizzy.
