b18c1blockw/arp,custom je pistons,ur race crank,gsr cranck, steelies b16 cams, manifold, ect.
Old Sep 30, 2007 | 02:26 PM
boosstboy's Avatar
prefer local buyers, but can ship at buyers expense unless otherwise noted. will only except pay-pal or cash at pickup. can take more pics on request. thank you to everyone who has purchased from me.
** will have new pic's up tomorrow and added items**
(PARTS FOR SALE)
1-- obd1 pr3 b series lower timing cover $25
2-- 96-00 civic stock cooling radiator fan $20
3-- d-series a/c compressor from 2000 civic $30
4-- infinity self powered sub works great w/ power/ground cables & rca cables $125
5-- new vibrant 3" flange stainless steel $15
6-- p73 2000 usdm type r ecu w/ imm removed $100
(PARTS SOLD)
1--stock '99 ex steelies no hubcaps or tires, but put in new valve stems----sold to traitorzxiong
2--new eagle rods w/big bolts b18c------ sold to uky07
3--stock b series spark cover light scratches and chipped tab------ sold to 94eg'n thanks
4--moroso aluminum oil pan (not the cheaper steel) deep sump w/oil pickup----sold to JDM1civic
5--partial d series turbo kit. rev hard mani, turbonetics t3 water cooled turbo(normal shaft play) , vortech fmu, 2.5" downpipe, 96-00 intercooler piping asking-----sold to mikeyspec
6--b18c1 block w/ new arp main studs ---- sold to pdiggitydogg
7--new in package acl b18c1 bearing set------- sold to uky07
8--used for 3 months ur race crank pulley & new belt -------sold to ef9_frosty
9--custom 85mm je pistons for use with eagle 2.2 stroker crank in a b18c 10.1 cr w/ b16 head no rings or locks brand new used for fitment check----sold to jcintegratyper thanks
10--b20b short block---sold to gong slow
11--usdm gsr hydro trans with quaife lsd mint condition---sold to local thanks andrew
12--billet hasport motor mounts b-series in ek---sold thanks andrew
13--custom 3" race dump off downpipe (meets at stock catback location) with magnaflow resonator and 45 degree cut---sold thanks chase
14--rc injector obdII plug and play conversion clips---sold to Kaj
15--new tial aluminum bov flange--- sold to boosted_b_series thanks
16--us (small vtec) black valve cover good condition--- sold to TRG thank you
17--laskey racing brand new benson's sleeved b16 84mm 9:1 comp, cp pistons, pauter rods, acl bearings, balanced and polished crank, waterpump, oil pump, rear water pipe, pcv box, alt mount's, oil pan with turbo drain fitting. ---sold to kte324 thanks
18--brand new in box omni 4 bar map sensor purchased from (mtber phearable.net)--- sold to kte324
19--act 6 puck unsprung disc good condition, 2 small corner chips on material --- sold to Got_booSt..? thanks
20--24.5"x8.5x15 M&H slicks alot of life left on bogarts just balanced with spacers and lugs--- sold thanks ron
21--billet crx b series cable mounts--- sold to 424racer thanks
22-- oem ctr camshats intake and exhaust with stock cam gears--- sold to EKLIS thanks
23--convertor (o2 not included) off of 00 si 10-12000 miles on it--- sold to scrap guy
24--stock jdm b16 springs, retainers, locks, and valves--- sold to maxwellmercer thanks
25--stock obd1 manual p28 ecu--- sold to sevenfc thank you
26--stock obd2 port matched b16 intake manifold---sold to ShandonWall thank you
27--tial 44mm wastegate and ss dump tube--- sold to xlr8ed thanks
28--b16 2 wire IAC sold to jgp321 thank you
29--aem wideband gauge, sensor, and harness's sold to local thanks marcin
30--RC injector saturated 750cc --- sold to h22 kid thank you
31--thermal 3" catback civic 96-00 coupe--- sold to ebp 99 si thanks
32--skunk2 pro series cam gears for b series siver new in box---sold to B20vEf9 thanks
33--96-00 civic stock a/c condensor and fan assebly with small line--- sold to ryc555 thanks
34--autometer boost gauge and line with light harness sold to a local
35--C&R civic half size radiator w/ spal fan, no leaks good condition sold to ron
36--dss 2.9 axles w/abs rings b-series in ek also fits in dc sold to ron
37--b-series RLD fab ramhorn mani, 3" ss dp sold--- Mattb16teg
38--ferrea roller cams and rockers brand new, newest style. sold----1sikek9
39--ferrea head package new in box ------sold to full race henry
40--aem ems 1050 box w/ serial data cable and cd with original box--- sold to blackem122
41--b16 oil pan with turbo drain fitting drain and feed lines---sold to velisma thanks again
42-- aem bypass valve 2.75" inner dia w/ new clamps--- sold to migrod1 thanks
43--fluidampr crank pulley w/ belt for alt---sold to cholo900rr
Old Oct 1, 2007 | 02:51 PM
boosstboy's Avatar
Default Re: b18c1blockw/arp,custom je pistons,ur race crank,gsr cranck, steelies b16 cams, manifold, ect. (b
bump for more parts added
Old Oct 2, 2007 | 08:28 AM
jsull.'s Avatar
pm me your number I have a friend that may want to pick up that type-r ecu.
Old Oct 2, 2007 | 01:22 PM
boosstboy's Avatar
bump for tuesday pmed jsull
Old Oct 3, 2007 | 02:05 PM
boosstboy's Avatar
bump bump bump
Old Oct 4, 2007 | 12:15 PM
boosstboy's Avatar
bump for the weeks almost over work sucks
Old Oct 5, 2007 | 10:47 AM
boosstboy's Avatar
bump need to sell.
Old Oct 6, 2007 | 04:32 PM
boosstboy's Avatar
ttt
Old Oct 8, 2007 | 05:20 PM
boosstboy's Avatar
need stuff sold bump
Old Oct 9, 2007 | 02:03 PM
boosstboy's Avatar
bbbuuummmppp
Old Oct 9, 2007 | 09:19 PM
Stillo's Avatar
would u trade your steelies for anything in the fs thread in my sig?
Stillo's Avatar
Old Oct 10, 2007 | 02:12 PM
boosstboy's Avatar
pm'd
Old Oct 14, 2007 | 12:02 PM
boosstboy's Avatar
sunday bump
Old Oct 22, 2007 | 05:45 PM
boosstboy's Avatar
ttt
Old Oct 29, 2007 | 04:40 PM
boosstboy's Avatar
bump for some offers
Old Oct 30, 2007 | 06:54 AM
ragnaroek's Avatar
cthulward
still have the steelies?
Old Oct 30, 2007 | 02:25 PM
boosstboy's Avatar
Default Re: (ragnaroek)
yup
Old Nov 3, 2007 | 04:36 PM
boosstboy's Avatar
Default Re: (boosstboy)
Old Nov 8, 2007 | 03:55 PM
boosstboy's Avatar
bbbuuummppp
Old Nov 14, 2007 | 03:58 PM
boosstboy's Avatar
ttt
Old Nov 18, 2007 | 11:41 AM
boosstboy's Avatar
bump for crank gone
Old Nov 18, 2007 | 12:19 PM
traitorzxiong's Avatar
Default Re: b18c1blockw/ arp studs,custom je pistons,ur pulley,14" steelies, b16 cams, manifold, ect. (booss
Pm sent
Old Nov 18, 2007 | 01:06 PM
boosstboy's Avatar
pme'd back
Old Nov 19, 2007 | 03:20 PM
boosstboy's Avatar
added pic of steelies bump
