type r bottom b16a
does anyone know if integra type r bottem end internals will drop in a b16a block. I want to build a stroker motor with a b16a engine and a gsr or type r crank, rods and itr pistons. does anyone know if this is a straight forward procedure or is there more to it?
pistons are straight drop in. you cant use itr/gsr crank and rods in a b16a block without custom pistons because of the b16's shorter deck height.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">pistons are straight drop in. you cant use itr/gsr crank and rods in a b16a block without custom pistons because of the b16's shorter deck height.</TD></TR></TABLE>
do you know who makes custom pistons to do this kind of build?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">any piston company can make you a set if you know the measurements</TD></TR></TABLE>
ok one more question lol. how do i find out the measurements?
b16nonoy
May 12, 2006 05:20 AM
