Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
K20 group
Old Sep 30, 2007 | 09:54 AM
Youngcity's Avatar
Default K20 group
whats going on fellas? Im tryna get into the k series. I got like 4000 grand saved up got a lil while to go before i can afford the full swap... so im tryna make my decision... between k20a2 n k20a3 or matts fav the k24a2..... i wanna run boost.. so iono if the k20a2 n k20a3 realle makes a diff if ima bore it 30 over and do the full rebuild..i just want sugguestions what you guys are running and if i can put a a2 head on the k20a3 with a fully built k20a3 bottom... will it be some what the same at the k20a2 fully built iono any suggestions would b highly appreciated cuz i can get a k20a3 for a decient price... just checking thanks.
Old Sep 30, 2007 | 11:53 AM
toyomatt84's Avatar
Sanji
There would be no point to run a K24a2 with a turbo. What benefits the K24a2 is it's higher compression. To run boost, you'd want lower compression.
Check k20a.org for some more helpful tips.
Old Sep 30, 2007 | 05:24 PM
polo609's Avatar
You could swap the k20a3, and then turbo it. I am in the process of saving up for k20 also, preferably the a2, but the price increases almost exponentialy from the a3 to the a2. I wonder what is a decent/avg price that someone should pay for either motor..
Old Sep 30, 2007 | 05:43 PM
katzenjammer84's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">There would be no point to run a K24a2 with a turbo. What benefits the K24a2 is it's higher compression. To run boost, you'd want lower compression.
Check k20a.org for some more helpful tips.</TD></TR></TABLE>
Uh, no point other than making good amounts of power. Moderate amounts of boost on stock K24A2 internals will yield very good results, especially having a nice torque curve and 2400cc to spool up the snail.
To run MORE boost SAFELY, you want lower compression. But there's nothing a good tune and good management can't fix.
Old Oct 1, 2007 | 12:20 AM
toyomatt84's Avatar
Sanji
Default Re: (AcuraFanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraFanatic &raquo;</TD></TR><TR><TD CLASS="quote">
To run MORE boost SAFELY, you want lower compression. But there's nothing a good tune and good management can't fix. </TD></TR></TABLE>
It'd still have a much shorter lifespan than a lower compression engine, and wouldn't yield as high of a gain.
Old Oct 1, 2007 | 06:39 AM
fventura03's Avatar
if u want boost, go with k24a1. a guy did 10s on his turbo k24a1 earlier last month, stock motor for the most part.
http://www.k20a.org/forum/show...k24a1
Old Oct 1, 2007 | 10:07 AM
Youngcity's Avatar
Default Re: (fventura03)
oh iight but for boost u want low comp. isnt the k24 high comp? its a real nice set up tho... wha you building freddy? in that hatch
Old Oct 1, 2007 | 10:21 AM
fventura03's Avatar
Default Re: (Youngcity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Youngcity &raquo;</TD></TR><TR><TD CLASS="quote">oh iight but for boost u want low comp. isnt the k24 high comp? its a real nice set up tho... wha you building freddy? in that hatch </TD></TR></TABLE>
ALL MOTA
Old Oct 1, 2007 | 10:28 AM
Youngcity's Avatar
all motor k24?
Old Oct 1, 2007 | 10:29 AM
fventura03's Avatar
yessss
Old Oct 1, 2007 | 10:32 AM
fventura03's Avatar
K24A1
* Found in:
o 2002-2008 Honda CR-V
+ Displacement: 2354 cc
+ Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
+ Compression: 9.6:1
+ Power: 156 hp (119 kW) @ 6000 rpm (166 hp @ 5800 rpm in 2007/2008)
+ Torque: 162 ft·lbf (220 N·m) @ 3600 rpm
+ Redline: 6500 rpm
K24A2
* Found in:
o 2004-2008 Acura TSX
+ Compression: 10.5:1
+ Power: 200 hp (147 kW) @ 6800 rpm (2004-2005)
+ Power: 205 hp (150 kW) @ 6800 rpm (2006-2007) *SAE Net Rev 8/04
+ Torque: 166 ft·lbf (225 N·m) @ 4500 rpm (2004-2005)
+ Torque: 164 ft·lbf (222 N·m) @ 4500 rpm (2006-2007)*SAE Net Rev 8/04
+ Redline: 7100 rpm
K24A3
* Found in:
o 2003-2006 Honda Accord (Europe, Japan, and Australia)
+ Power: 189 hp (140 kW) @ 6800 rpm
+ Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm
+ Redline: 7000 rpm
K24A4
* Found in:
o 2003-2005 Honda Accord, 2003-2008 Honda Element
+ Compression: 9.7:1
+ Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
+ Torque: 161 ft·lbf (218 N·m) @ 4500 rpm (@4000 rpm in 2007/2008)
+ Redline: 6500 rpm
Old Oct 1, 2007 | 10:47 AM
onefstek's Avatar
turbo K24a1 with some nice cams and you can make what I made.
356 whp 272 wtq at 8psi boost.
Old Oct 1, 2007 | 10:50 AM
fventura03's Avatar
^damn, nice numbers.
Old Oct 1, 2007 | 11:12 AM
xandrake's Avatar
Default Re: K20 group (Youngcity)
4000 grand is a lot of money. Why're you wasting your time on a honda? ;-)
Old Oct 1, 2007 | 11:26 AM
fventura03's Avatar
Default Re: K20 group (xandrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xandrake &raquo;</TD></TR><TR><TD CLASS="quote">4000 grand is a lot of money. Why're you wasting your time on a honda? ;-)</TD></TR></TABLE>
What do you think he should waste his 4000 grand on? a ferarri?
Old Oct 1, 2007 | 11:29 AM
daddy's Avatar
4000 grand is alot of money cuz thats 4 million dollars!!!! lucky for him hes only spending 4grand
Old Oct 1, 2007 | 11:31 AM
thinknology's Avatar
Your wasting your time on this site then.... also wasted your time typing out ;-) when you just could have typed out
Old Oct 1, 2007 | 03:55 PM
Youngcity's Avatar
Default Re: K20 group (thinknology)
lol this is an expensive love/sport... you gotta spend money to get what you want i want a k series its looking like the k24 is the way to go so you got that wit cams and boost...
Old Oct 1, 2007 | 04:25 PM
fventura03's Avatar
it's definitely $$$$$
Old Oct 1, 2007 | 04:46 PM
Youngcity's Avatar
lol well yea i knew that from the get go...i know ima be spending at least 20k to have the motor fully built with turbo n everything else
Old Oct 6, 2007 | 08:17 AM
onefstek's Avatar
Defenetlly worth the money if you ask me. I would do it again and again if I had to start over. It would be even cheaper if I knew then what I know now. I would have never wasted my money on some other stuff.
Old Oct 6, 2007 | 12:47 PM
Youngcity's Avatar
Default Re: (onefstek)
yea thats how it is you learn as you go... and the real bitch is the labor.... gotta learn to do it your self and you'll save alot more money....
Old Oct 6, 2007 | 12:55 PM
ALL MOTOR EM2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">if u want boost, go with k24a1. a guy did 10s on his turbo k24a1 earlier last month, stock motor for the most part.
http://www.k20a.org/forum/show...k24a1</TD></TR></TABLE>
Yeah Thats whats up k24a1 turbo pulling 10's.
Old Oct 7, 2007 | 05:02 PM
1llmatic's Avatar
New User
Default Re: (ALL MOTOR EM2)
This isn't really accurate. High compression motors on boost make great power with less boost. Proper tuning and water/meth and you would have great numbers on the type R.
the k20a2 is 11.1 compression and there are alot of guys boosting making sick numbers.
10:5:1 compression isn't really that high for the k24a2.
If it were me I would go with the k24 block with a k20a2 head.
just my 2 cents...
Old Oct 10, 2007 | 11:19 AM
Ya Digg's Avatar
4000 Grand. LOL he has 4 million saved up. HA
