How is everyones thermal dynamics?
Thanks but thats not exactly what I'm looking for. I'm not looking for thermal conductivity, I'm looking for thermal dissapation.
I dont get it. I was never too great at physics. I would like to know how well a material with an R value of 1.6 refract heat as compared to other materails. I am looking for a good thermal wrap that can withstand header heat.
Something like this....
Insulation type R-value per inch of thickness
Fiber glass blanket or batt 2.9 to 3.8 (use 3.2)
High performance fiber glass blanket or batt 3.7 to 4.3 (use 3.8)
Loose-fill fiber glass 2.3 to 2.7 (use 2.5)
Loose-fill rock wool 2.7 to 3.0 (use 2.8)
Loose-fill cellulose 3.4 to 3.7 (use 3.5)
Perlite or vermiculite 2.4 to 3.7 (use 2.7)
Expanded polystyrene board 3.6 to 4 (use 3.8)
Extruded polystyrene board 4.5 to 5 (use 4.8)
Polyisocyanurate board, unfaced 5.6 to 6.3 (use 5.8)
Polyisocyanurate board, foil-faced 7
Spray polyurethane foam 5.6 to 6.3 (use 5.9)
I was thinking more along the lines of painting my header with either ceramic paint or heat safe paint black, and then using some sort of wrap that will withstand the heat.
http://www.jm.com/insulation/product..._Microlite.pdf
Edit: However, this stuff can only withstand 350 F which is not nearly enough.
[Modified by Wont be beat, 11:17 AM 6/19/2002]
It's just a conversion factor, to whatever you want, insulating R value can be in inch/cm/etc... but you have to say which...
Ahh, thermal wrap, you are looking for insulation, i'm using dei header wrap... with dei silicone coating, both from summitracing for cheap...
As for the ideal header wrap... aerogel
http://science.nasa.gov/aerogel/
http://eande.lbl.gov/ECS/Aerogels/satcond.htm
Unbelievable stuff and all that is needed to insulate entire exhaust weighs less than a penny! Plus it's not as far off an idea as you think, it is already being made as insulation for ski jackets and other winter clothes.
Otherwise, more expensive than fiberglass headerwrap... http://www.3m.com/market/industrial/...barriers.jhtml
Your choice.
Your choice.
the problem with the heat wrap if the pipe has not been coated is it traps moisture between the surfaces and your piping will rust at an accelerated rate
Cool, I live right by Summit Racing. I may get some this weekend.
Misa , what do you coat that stuff with to prevent the moisture problem?
i didnt coat, but on my next set of whatever the hell i decide to do if i decide im not sick of all this crap
would be have it sent off to be coated http://www.hpcoatings.com
