Which is best
Old Sep 29, 2007 | 06:58 PM
jnate189's Avatar
Default Which is best
I am deciding wether to mod my regular stock 4-cylinder v-tech engine that came in my 98 honda accord. i was going to add an expensive turbo kit to it, the problem with that is that the engine has 160,000 miles on it. i want to get my engine horse power up to about 225-250 so that i can drive it on the road normally. i was debating wether i should go ahead and get a new h22 engine instead of adding on the turbo kit. which would be better in the long run with less headache?
Old Sep 29, 2007 | 08:40 PM
JDM_Acccord's Avatar
Default Re: Which is best (jnate189)
first your spelling needs to be corrected.
second, it's vtec.
third, it's going to take a lot of work and hell to get 250 more horsepower. if you want to boost.. i would make sure your car and it's engine is in right condition.
Old Sep 29, 2007 | 10:21 PM
shibbywhitedude's Avatar
Depending on the amount of money you have, I would go for the H22 swap. Headache? I'm not sure... I would think it would probably be more of a headache to boost an old motor and blow it and have to end up getting a swap after all. Just my opinion.
Old Sep 30, 2007 | 03:29 AM
Doostur's Avatar
Well the possibility of less headaches I think will occur with just the h22 swap.
Reguardless if everything is done right, both are headacheless
DoobieMarks101
Aug 20, 2008 08:53 PM
DiZwHaT
Jul 20, 2007 11:06 AM
Corruption
May 15, 2005 06:42 PM
Corruption
May 8, 2005 06:24 AM
all420
Dec 16, 2002 04:46 PM
