help with si cam in stock dx...
Old Sep 29, 2007 | 02:41 PM
efnick's Avatar
Default help with si cam in stock dx...
ok so i got an si cam shaft/ gear from a junker. i want to swap it into my 90 dx(d15b2 i belive?) i need to know what other things i may need to make it work, like do i need the d16 timing belt? will i have to reset the lash on my valves? i got the gear and the shaft, so what things will i have to re set and how do i adjust the timing, do i move the gear on the shaft, the belt on the teeth, or what? and, will the bearing fit into the stock races without binding?
Modified by efnick at 4:02 PM 9/29/2007
Old Sep 29, 2007 | 05:13 PM
The_Undertaker's Avatar
75.168.105.221
It will fit and upgrade injectors and whole head components.
Old Sep 29, 2007 | 06:26 PM
turbostd's Avatar
Default Re: help with si cam in stock dx... (efnick)
use a d16y cam gear to correct a 1/2 tooth timing diffrence.
Old Sep 29, 2007 | 06:35 PM
efnick's Avatar
Default Re: help with si cam in stock dx... (turbostd)
so the gear from any d16y series? what usdm cars came with that engine in them? i cant use the si cam gear?
Old Sep 29, 2007 | 07:52 PM
turbostd's Avatar
any 96-00 iirc. You can use the si gear but cam timing will be 4.75 deg off.
Ef4doorwagon
13
May 17, 2014 06:09 PM
Cuong-nutz
May 16, 2005 03:55 PM
4thgenHB157
Feb 19, 2005 08:10 PM
the DR.
Mar 18, 2002 05:13 AM
