Dumb engine light
Old Jun 18, 2002 | 03:31 PM
Frosty_spl's Avatar
Default Dumb engine light
im throwing a code 6, which is the water temp sensor right? I changed it and its still there, so i took the new sensor back sence its 30 bucks. What is the problem? TIA
Old Jun 18, 2002 | 03:51 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Dumb engine light (Frosty_siR)
...did u reset ur ecu?
Old Jun 18, 2002 | 04:40 PM
the DR.'s Avatar
Default Re: Dumb engine light (xxkenyon419xx)
maybe you need to figure out the problem instead of just the fix for it... like the other day i had a o2 sensor content (code 1) it says to replace the o2 sensor, i put in another one i had and after a while same thing, my point is, find the problem, not just the solution
Old Jun 18, 2002 | 09:37 PM
Frosty_spl's Avatar
Default Re: Dumb engine light (CIVICtypeS)
i reset it.
O2 content means the o2 is gettin messed up from something in the engine, not just a bad sensor. A code 6 is just a bad sensor.
Old Jun 18, 2002 | 09:51 PM
crx_91si's Avatar
isn't there 2 coolent temp sensors? One under the upper rad hose and one on the back of the block(on a D16A6)? I could be mistaken
Old Jun 19, 2002 | 07:57 AM
EternalFootman's Avatar
Check and make sure you dont have a short in that area of the wiring harness... If water or coolant got into teh harness, and one of the wires has a small slit in it, you could be throwing all sorts of codes eventually. And I know that sounds far fetched, but I know quite a few people, Hondas, Acuras, Saabs, ect. that have had that same problem!
And make sure you reset your ECU!!!
dave
Old Jun 19, 2002 | 11:30 AM
Frosty_spl's Avatar
Default Re: Dumb engine light (EternalFootman)
i had to replace the harness on the water temp sensor because one wire broke off at the top of the plug. i butt connected another one on and it was still there.
i have a b16a btw.
Old Jun 19, 2002 | 12:18 PM
wronghand's Avatar
The butt connector could easily be your problem. Go back in and solder the wires. That is where I would start.
Old Jun 19, 2002 | 01:06 PM
customx_'s Avatar
New User
get a PW0 ecu
Old Jun 19, 2002 | 03:42 PM
Default Re: Dumb engine light (wronghand)
AGREED!!!
dave
Old Jun 19, 2002 | 07:46 PM
Frosty_spl's Avatar
ok thanks guys. i have a pr3 with a spoon program.
Old Jun 20, 2002 | 05:18 AM
88_SC_CRX_Si's Avatar
New User
Default Re: Dumb engine light (crx_91si)
The sensor on the back or side of the block, is used for kicking on the cooling fans...
bigfoot89
Engine Management and Tuning
Dec 21, 2011 05:22 AM
Koyoloeor
Oct 13, 2005 04:57 PM
vtec-adykt
Sep 12, 2005 01:09 PM
bumthology
Oct 5, 2004 03:18 PM
89Si
Apr 21, 2002 07:24 PM
