Skunk2 stage2 cams vs Toda Spec C!
which one is better? I have skunk2 valvetrains + skunk2 stage1 cams already but I look for more hps....which should I go for? i need your help guys.
I can't find any link to read about these.
1) is Toda spec C too much for street car?
thank you
thank you
if you already have all skunk2 internals i woulc probably stick with the skunk2 theme, things seem to just run more smoothly when you run things together that were made to be together. just a thought though
engine B18c1......all N/A (complete from intake manifold --> exhaust) + skunk2 valvetrains + skunk2 stage1 cams + tuned...... no head ported
I put down around 170whp, car weight 2540 (driver included)...... ran 14.53@96mph....... i wanna break into 13s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sherdog9 »</TD></TR><TR><TD CLASS="quote">ran 14.53@96mph....... i wanna break into 13s</TD></TR></TABLE>
Lose weight or pick up about 50 HP. The Toda C's are fine for a daily driver.
What kind of compression are you running? Toda C's from my experience work better on something higher than a stock GSR level. They will also require more tuning time to get them "right" than S2S2's but will make more power if your engine parts and tuning are well matched.
if ur comp is high enough than the toda c's would be a good choice but imo i would stick with skunk2. the toda c's have larger primary lobes than the skunk2 tuner series cams which is better for a high comp all motor setup but i dont think they would be the right choice for your setup.
thanks guys.... i don't have upgrade compression.....it seems like i'll stick with s2s2 which are cheaper. I had skunk2 stage1 cams and did not impress me much.
Well... if you’re contemplating running the Toda C's then you might want to think more about running the Skunk2 Pro 1's. I think this more fair a comparison.
Things you want to have prior to swapping the cams...
Bump in compression (thinner head gasket, maybe flat faced valves, and/ or mill the head).
Skunk2 IM
68mm T/Body
4-1 Header (maybe a DC JDM Type R unit)
70mm Exhaust
Re-tune
this thing will sing! You should be in the 190-200 range.
Skunk2 IM
68mm T/Body
70mm Exhaust
Re-tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duckiller00 »</TD></TR><TR><TD CLASS="quote">Well... if you’re contemplating running the Toda C's then you might want to think more about running the Skunk2 Pro 1's. I think this more fair a comparison.
Skunk2 IM
68mm T/Body
70mm Exhaust
Re-tune
instead of all that, how about a
b20 bottom end
rs or sparks b20 type r style pistons
edelbrock pro-flow header w/2.5 collector mod
use whatever exhaust you're already using
retune
even with the current cams, you'll get 210-215 and a crapload more of torque.
Skunk2 IM
68mm T/Body
70mm Exhaust
Re-tune
</TD></TR></TABLE>instead of all that, how about a
b20 bottom end
retune
^^^here are what i have
b18c1 (70k)
Skunk2 stage1 cams
Skunk2 pro valvetrains
Skunk2 70mm throttle body
skunk2 pro-series intake manifold
DC sports JDM header 2.5 collector
2.5" OBX cat
2.5" exhaust (tanabe)
exedy stage 1 clutch + flywheel
3" CAI
Crome tune
Now i need bigger cams or higher compression.... i want to make at least 180hps
b18c1 (70k)
Skunk2 stage1 cams
2.5" OBX cat
3" CAI
Crome tune
You will need one or both of these...
Compression and/ or Displacement
Running that B20 bottom end would change all kinds of stuff! I was at Church and a guy from the Valley was tuning his stock bottom end LSVTEC and running our Pro 1's... he made 218 and it was all chocked-up on the exhaust side.
i would still do the edelbrock pro-flow header. it will OWN the jdm dc header. a lot more midrange and atleast 3-4 hp more up top.
EGfoSheezy
Oct 4, 2005 03:25 PM
jeremy.
13
Jan 2, 2004 01:13 AM
