Remove speed limiter/governor 2001 accord ex v6 HELP!!!
I need help. I have searched far and wide for a way to remove the speed limiter/governor from my 2001 Honda Accord EX-V6 coupe and have found nothing; my car tops out at 105 and I want to supercharge it but I do not see the point since I won't be able to do much on the track with the governor on. Hondata does not make a remapped ECU for my car and there are no chips that I could find to override it. PLEASE HELP, if you have any idea who has the solution I would greatly appreciate it. Thanks.
What kind of racing are you planning on? ie. drag, autoX, etc.. Also, is this car a daily driver? Finally, this topic has been covered way too many times. If you search, you'll find your answer (hint. check the archives, I'm certain I have seen an answer in there before.).
jca1972
Dec 30, 2005 08:49 PM
