planned to build a poorman's ITR engine
Old Sep 28, 2007 | 06:02 PM
RACING INTEGRATION's Avatar
Default planned to build a poorman's ITR engine
here what's i'm planning..
b18c1 block
82mm CTR pistons
arp rod bolts
ITR flywheel
ITR head
spoon cams
ITR or blox intake manifold
68 or 70mm TB
thermal intake gasket
ARP head studs
AEM v2 intake
microtech EMS
can I get to 200 WHP with this setup?
Old Sep 28, 2007 | 06:51 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: planned to build a poorman's ITR engine (RACING INTEGRATION)
(1) Get a better set of cams. Sk2, rocket, etc.
(2) What sort of header are you plan on using? at least a tri-y copy
(3) Also, your compression will be pretty high with CTR pistons. Maybe you should think about p30s or better yet wiseco 11:5.
(4) Are you planning to port the head?
Old Sep 28, 2007 | 07:43 PM
Default Re: planned to build a poorman's ITR engine (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">(2) What sort of header are you plan on using? at least a tri-y copy</TD></TR></TABLE>
Toda or Mugen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">(4) Are you planning to port the head?</TD></TR></TABLE>
if I get a ITR head, I will leave it stock...
if I don't find one.. I will look for a port&polished b16 head
Old Sep 28, 2007 | 09:17 PM
all-mtr-teg's Avatar
Isn't a 65mm TB a better choice, unless you get a ported head won't 70 or even 68mm TB be overkill?
RACING INTEGRATION
10
Dec 10, 2007 12:56 AM
RACING INTEGRATION
31
Oct 22, 2007 08:08 PM
jaydmcrx
Jul 23, 2004 08:58 AM
hatched92
Apr 12, 2004 07:22 PM
