Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Accord Transmission Security System
Old Sep 28, 2007 | 02:45 PM
creator1322's Avatar
Default 03 Accord Security System
So does the anti-theft system that comes with my accord actually "LOCK" the ECU from allowing the car to start?
Basically, is it really possible to steal the car without a key that has been properly "chipped" to allow the car to start?
I just want to know how this system works....
Thanks!
Old Sep 28, 2007 | 04:25 PM
BLKFLSH's Avatar
Default Re: 03 Accord Security System (creator1322)
The owner's manual for my 03 EX V6 says the immobilizer system works by disabling the fuel system (doesn't explain how though). Do you really have 115,000 miles on it? Is it an automatic? Have you had any transmission problems? Just wondering
Old Sep 28, 2007 | 08:06 PM
02 accord's Avatar
If the ECU doesn't receive the correct code from the key, the car will not start. This can be bypassed by swapping out another ECU and using a key that was programmed to that ECU. The car can also be towed away.
Old Nov 28, 2007 | 02:34 PM
p10hlm's Avatar
Default Re: 03 Accord Security System (02 accord)
or you can use a cut key and the brake code
Old Nov 28, 2007 | 06:43 PM
s13_240sx_92's Avatar
Default Re: 03 Accord Security System (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">The owner's manual for my 03 EX V6 says the immobilizer system works by disabling the fuel system (doesn't explain how though). Do you really have 115,000 miles on it? Is it an automatic? Have you had any transmission problems? Just wondering </TD></TR></TABLE>
It appear that Honda still didn't correct the defects in their trannies.
Get out while you can..
http://www.carcomplaints.com/H...shtml
Old Nov 29, 2007 | 06:38 AM
Default Re: 03 Accord Security System (s13_240sx_92)
No transmission problems yet. I've heard I should have some though...there was a recall to get a "jet" system added to the tranny, haven't had it done yet. I'm bout to go in for timing belt and water pump.
harvey1078
Sep 24, 2012 08:13 AM
gwchndlr
Jan 20, 2007 05:40 PM
dbdragstar
Jan 19, 2007 02:47 AM
RuskeR
Jan 30, 2006 08:11 PM
captainkgun
Oct 2, 2003 05:27 PM
