SURGING H23A1
Old Sep 28, 2007 | 12:57 PM
REDLUDE4WS's Avatar
Default SURGING H23A1
THIS IS JUST STUPID. 93 SI 4WS, SURGES AT IDLE, RUNS MINT OTHER THAN THAT, NO VAC LEAKS, MAP WORKS FINE. I HAVE BEEN A TECH FOR YEARS, HAVE A SNAP ON SCANNER, ALL PARABLES FINE, ONLY THE DUTY CYCLE IS FLIPPING OUT. HAS ANYONE HAD THIS PROBLEM?
Old Sep 28, 2007 | 01:47 PM
AndyD's Avatar
Default Re: SURGING H23A1 (REDLUDE4WS)
As weird as this may sound but my car did the same thing. I found out the coolant was low. Once I filled it up, it ran fine. Worth giving it a shot.
Old Sep 28, 2007 | 01:59 PM
Acidcrakker's Avatar
Default Re: SURGING H23A1 (AndyD)
Im sorry would you mine explaining what serging means. If its what I think it is (the motr is reving itself) I had that happen to me the other day and my coolant was low as well, but I think its a vaccum line right next the EGR valve was capped off. I filled coolant up and un capped the vaccum line and it stopped reving itself. (Im a noob)
Old Sep 28, 2007 | 02:09 PM
97LXF20B's Avatar
IACV? Taking mine off and cleaning it out with brakleen worked like a charm to stop idle surge. EGR valve or purge solenoid malfunction can also cause this.
Old Sep 28, 2007 | 02:28 PM
boostedh22lude1's Avatar
this may sound stupid but check you powersteering fluid level itruns through the trans. and can cause a surging idle if it gets too low/ alsoiacv
deeweezy187
Dec 3, 2005 08:50 PM
civiclxb16a
11
Apr 27, 2005 06:20 PM
team2n1hatch
10
Apr 2, 2003 03:32 PM
Ri5e
Aug 25, 2002 08:23 PM
LsTurbo91
Dec 18, 2001 12:23 AM
