What clutch will fit a first gen b16a?
I know, search search search. I have indeed done this..but every topic that get's pulled up is mixed with different answers and and even more questions. So here it is.
What car/tranny should I order my clutch for so it will fit my first gen b16a? I already have a clutch at the house for a 92-93 GSR w/ cable tranny, will this work? What's the deal with the large spline/small spline b16a's....Ive even talked to the people at excedy..they basically told me that the only way to find out would be to pull the tranny...I kinda dont have the time due to the fact that this car is my daily D and I have to drive 20 miles and back for school every day. Thanks guys.
B series cable trans from 92-93 tegs are the large spline versions...
If its a first gen b16 and it has the stock transmission, then its the small spline version... so get a clutch kit for like a 90 teg.
If you try to use a clutch disc made for the large spline on a small spline tran it will fit but have slop which is no good... if you try putting a small spline clutch on a large spline tran it just won't fit. I am pretty sure that the big spline pressure plates and throwout bearings are also incompatible with the large spline and vice versa...
clarkekent13
Transmission & Drivetrain
Feb 7, 2010 04:27 PM
