Bent Rotors
Old Jun 18, 2002 | 02:19 PM
Junglist's Avatar
Default Bent Rotors
If the stearing wheel shakes at high speed braking, we can say that one of the front rotors is bent, correct? If so, how do you tell which side it is or both?
thanks again,
b
Old Jun 18, 2002 | 02:32 PM
slowassR's Avatar
Default Re: Bent Rotors (Junglist)
If it only does it at high speed it could just be your abs. Its posible. Does the wheel jeark hard in different directions when you break or is it more of a steady pulsating?
Old Jun 18, 2002 | 02:38 PM
junglistgsr's Avatar
thanks again,
b
you'd say its warped, not bent.....i dont think your wheel would turn if you had a bent rotor and if it did it would make some nasty noises when the bent part made contact with the caliper and bracket.
your rotors are most likely warped, you should be able to get them resurfaced for cheap.
Old Jun 18, 2002 | 02:47 PM
Junglist's Avatar
Default Re: Bent Rotors (slowassR)
yeah it's a steady pulsating.
who can resurface in SoCal? How much is a fair price?
thanks once more,
b
Old Jun 18, 2002 | 02:51 PM
Back in Black's Avatar
Rather OG
To hell with resurfacing...
Just buy a new set from Autozone. You want the front rotors from a 1995 Acura Legend...
Jason-
who still can't believe they work as well as they do
Old Jun 18, 2002 | 02:53 PM
slowassR's Avatar
does it happen at 30mph ? ITs very posible that its just your abs. how many miles do you have on your car? ill im you
[Modified by slowassR, 7:06 PM 6/18/2002]
Old Jun 18, 2002 | 02:56 PM
Junglist's Avatar
80 mph +
Old Jun 18, 2002 | 03:20 PM
IVANITR's Avatar
Someone elaborate on which rotors should be bought from Autozone? The 1995 Acura Legend? What's the difference between the ITR one and the Legend. Do they even make a rotor for the ITR from Autozone?
Old Jun 18, 2002 | 03:27 PM
Rather OG
Default Re: Bent Rotors (IVANITR)
Courtesy of Willard on this board...
https://honda-tech.com/zerothread?id=181691
glulude
May 1, 2007 04:57 PM
AViciousTHRUST
Apr 2, 2006 08:30 AM
..::91TEG-G2::..
Aug 12, 2003 03:25 PM
Brian-Brian
Jul 17, 2003 06:35 AM
YNOT
Mar 25, 2002 08:03 PM
