ANY ONE HAVE THIS BOLT (AEM FUEL RAIL)
Old Sep 28, 2007 | 09:49 AM
CHEFH22HATCH's Avatar
Default ANY ONE HAVE THIS BOLT (AEM FUEL RAIL)
i snapped the bolt that connects the fuel line to the rail aem wont sell just the bolt nor will distributors.............. im not going to spend a 150 ona new fuel rail for just the threaded bolt
thanks help a brother out
93 h22a1
Old Sep 28, 2007 | 10:33 AM
Hawkze_2.3's Avatar
Default Re: ANY ONE HAVE THIS BOLT (CHEFH22HATCH)
The Banjo bolt? I have an extra damaged rail with hardware in my garage...
Old Sep 28, 2007 | 10:35 AM
Finest's Avatar
Are you talking about the banjo bolt? If so, the local Honda dealer has them.
Old Sep 28, 2007 | 10:47 AM
the banjo goes into the fuel filter i need the one which is threaded to go into the rail
it goes from the rail to the fuel line which gets bolted on top to hold the line down
Modified by CHEFH22HATCH at 3:00 PM 9/28/2007
Modified by CHEFH22HATCH at 3:04 PM 9/28/2007
Old Sep 28, 2007 | 11:02 AM
preludestud11's Avatar
I could never find one. What i ended up doing was getting a plug fitting that screwd into it, then tapping the plug right in the middle for a bango bolt to fit it. It was kinda ghetto but it worked well.
Old Sep 28, 2007 | 11:08 AM
Default Re: ANY ONE HAVE THIS BOLT (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">The Banjo bolt? I have an extra damaged rail with hardware in my garage...</TD></TR></TABLE>
let me know asap
thanks
Old Sep 28, 2007 | 01:46 PM
nonvteclude's Avatar
i did this a couple years ago. i called aem and they sent gave me the number for someone else to get them. they are like $20 a piece. so instead of having to go through all that hastle again i bought 3. call them and they can hook you up.
Old Sep 28, 2007 | 02:59 PM
Default Re: ANY ONE HAVE THIS BOLT (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">i did this a couple years ago. i called aem and they sent gave me the number for someone else to get them. they are like $20 a piece. so instead of having to go through all that hastle again i bought 3. call them and they can hook you up.</TD></TR></TABLE>
aem prefers to smoke pole as apossed to helping the customer.... told me to call a retailer which does not help a all if you still have an xtra one let me know thanks
Old Sep 28, 2007 | 03:38 PM
yes you have to call a retailer. they can get you the numbers for them. aem works off of a wholesale enviroment which only allows you to by through a retailer. but maybe someone will have one on here.
Old Oct 10, 2007 | 09:22 AM
delete me i got one thanks again fellas
civictype-r
May 26, 2010 08:30 AM
supaf1y
May 26, 2008 10:02 PM
h22silvia
Mar 27, 2007 01:45 PM
4ghatch
Sep 2, 2005 08:19 PM
